Roll up some material (felt / whatever you're using to line the cabinet) and stuff it in the vent. Quite literally. Then adjust the quantity to suit. Like this, from Troels Gravesen's site:
Now i'm back on track again How thick should the felt be?
a standard thickness often used for panel lining is 1/2" or so
Thats like 12,7mm? Ill see what i can find
Any progress to report?
Not quite yet, i was distracted by a entirely different project, so this is still pending.
I am building another pair of speakers with bamboo and have a little piece left, which i have planned to use for this project. I will update this thread with more news. Although i have a tiny problem right now, which is sourcing a proper bassreflex tube in Europe for this speaker..
What's the port you need that is so difficult? (dimensions/plastic/paper)
You can build diy in plastic or paper, or buy if you want.
You can find good ports in the trash, just cut to dimension.
Monacor Tuning Ports
Porting at Subwoofer-Builder.com
Google - BUILDING A SUBWOOFER BOX WITH PVC AERO PORTS - YouTube
I will need a 30mm, so i think this might be suiteable:
Monacor BR-30HP 30mm Bass Reflex Tuning Port Tube 1.34 IN STOCK (18 May 2014)
- Full Range
- Cabinet for small 3" fullrange speaker
