It's a shame the header on the minisharc was not laid out to accept the curryman DAC option in a way that would allow the use of ribbon cable without splicing and seperation of the one connection end.
I wonder when they will get more DACs in. If well implemented, you are basically listening to the output of an oppo103. I have V3 of the Subbu DAC and will compare to V1 as well as Oppo105.
That would be great! Await the details of such
And concur with your assertions
Where have you got that opamp stuffed?
Had a google for it and the Texas instrument boys said this little fellow gave considerably better performance.
Operational Amplifier (Op Amp) - High Speed Amplifier (>=50MHz) - LMH6622 - TI.com
May or may not be of interest to you
Back on thread. (No, I don't mind the hijack. Keep it up. I am learning a few things outside of my skill set.)
Swapped out the A10P's for A7.3's. Oh, my! Now I remember why the A7.3's have always been my favorite MA drivers. The A10's have been banished to the HT for a month. They either need way more break-in, or indeed the A7.3's are much smoother.
I was having a problem with a hole in the FR around 200Hz. I suspect a combination of floor and ceiling bounce. Offsetting the XO went a long way to fixing it. Usually, the gentler slope is put on the top, but I have 200Hz LR12 on the bottom and 150Hz LR48 on the top. The acid test for me is to run a cello up and down over the XO. Passed.
Second interesting finding, but I knew this all along. I EQ's the system flat 20-20K (well, 15K anyway). The overall sound was a bit flat and thin. So I built a F-M EQ curve in the music player with 6dB boost at 20Hz. It's wonderful! I guess we are all bassheads at heart, aren't we?
A final note. Over at the MA forum, most everyone is clamoring for a very light paper woofer to put under their wide rangers. Got to have a "fast" woofer, you know. Darn it! My massive aluminum subs integrate beautifully with the A7's. Once you have felt a true 20Hz note, you can't go back.
Bob
Bob
Yo-yo Ma for my money.
I've got 4-500hr on my A7's and I still wouldn't call them smooth. Slick maybe, exciting definitely but a bucketful less of the smooth compared to my 10.3ms 1000hr plus. I'm begining to wonder if the actual burn in time isn't nearer 1000hr than the 300hr.
I do like Bach's Cello Suites, have an EMI Classics recording by Paul Tortelier of suites 1 to 6... Yo-yo Ma certainly, Julian Lloyd Webber also
Just about to order a second pair of A7's for some sealed enclosures. I want to keep my FH3 fitted A7's where they are, as they're lovely sounding speakers. I only have a selection of old Mission speakers to compare them to, which just can't compete.
I'm beginning to wonder if the actual burn in time isn't nearer 1000hr than the 300hr.
Well, let's see. My A7.3's have been in the HT for 2yr, say 4hr/day, 6days/week, 300 days/year. That's 14400hr. Yep. They are broke in!
Bob
- Full Range
- Playing with the nanoDIGI
