alpair 12 studio monitor
Old 5th February 2014, 02:18 PM   #1
nirvana is offline nirvana  Canada
Default alpair 12 studio monitor
Hi , what kind of bass can produce the alpair 12 double-bass monitor studio
from Mark Audio. ?
Give me the lower freqnency please. Would I obtain good results with a first watt j2 ?
thank you.
Old 5th February 2014, 06:17 PM   #2
chrisb is offline chrisb
That'd kinda depend on how large an enclosure you could accommodate - I've heard a single A12P in only two enclosures - the SuperPensil and a smallish standmount "miniOnken" - the larger enclosure wins in terms of low frequency extension and slam.
Be aware that the A10P is probably capable of the same extension in smaller enclosures, at the penalty of 2dB of sensitivity
Any particular reason for 2 12Ps?
like my mind, this space intentionally blank
Old 5th February 2014, 07:21 PM   #3
Double bass REFLEX cabinet ... sorry. Studio monitor for A12P .
Old 5th February 2014, 07:49 PM   #4
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Didn't know such a design existed for the 12p. Could you post a link?
jeff
Old 5th February 2014, 07:52 PM   #5
http://www.diyaudio.com/forums/attac...80610-plan.gif
Old 5th February 2014, 08:02 PM   #6
IINM that would have been for the A12 metal - quite a different animal from the current 12P - I should think the design would be a poor match for the new driver
Is this actually for a studio monitor situation, and which driver do you have or will be acquiring?
If compact size is a factor, there's a small BR design for A10P that's reputedly quite OK - I haven't heard them yet.
Old 5th February 2014, 08:09 PM   #7
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
The single driver 12P would be truly unsuitable as a studio monitor because of its erratic frequency response. From the graph shown here, from 130Hz to 17K Hz. From a 90 Db baseline, a -4 Db hole at 470 Hz, and a train of +8Db "ripples" on out to 17K. Forgive me here but you try to master anything with this ragged a response & ....who knows what you'll wind up with.
Monitors should be shooting for a -2+2 Db range ...not a -4 to an +8 Db, let alone a roller-coaster graphing.
________________________________________________Ri ck.............
Old 5th February 2014, 08:34 PM   #8
Godzilla is offline Godzilla  United States
Godzilla's Avatar
I was recently at Sam Ash with my boys and we had a chance to hear and compare all the studio monitors they had on display. I don't recall all the brands but they had Dynaudio, Fostex, Krk, Yamaha, Jbl and some others. They all sounded totally different, barely similar and were all subject to personal taste. They all may measure flat but they certainly sounded different.
Old 5th February 2014, 08:41 PM   #9
buzzforb is offline buzzforb  United States
buzzforb's Avatar
J2 sounds excellent on the MA drivers I have had. I would suggest a tweeter for the A12. Heresy, I know, but it is more about improved balance, top to bottom, and improved imaging. I am strongly considering the 10p for a mid in a monitor style setup with N26C tweeter and supporting woofer. MA drivers haev the most wonderful sound and are really only limited by physics. Anyone who speaks against them either has not listened to them or has not accepted these limitations. Most crossovers I have heard are much more easily identified than the variations in the frequency response seen above. Look at the 7.3 response. I can assure you the other than lacking in sub 50Hz bass, and slight loss of image up high due to beaming, it sounds spectacular.
...Shape the sound , Man!
Old 5th February 2014, 08:44 PM   #10
Godzilla's Avatar
I will have to eventually buy a pair of MA.
alpair 12 studio monitorHide this!Advertise here!
Twin Alpair 7's studio monitor build. lorienblack Full Range 44 19th October 2016 11:31 PM
Alpair 12 with passive radiators for near field monitor? 18Hurts Full Range 17 28th June 2011 11:02 PM
Alpair 12 Studio Reference Monitors fired up Douglas Ingram Full Range 71 11th June 2011 07:45 PM
