Old 23rd January 2014, 09:23 PM   #1
tca is offline tca  Portugal
tca's Avatar
Default Bradford Perfect Baffle
Did anyone tried this?
Here is the patent: https://www.google.com/patents/US2834423
and some more info: retro vintage modern hi-fi: Bradford Perfect Baffle
Cheers.
"The future is here, it's just not evenly distributed yet." -- William Gibson
Old 7th February 2014, 10:04 PM   #2
tca's Avatar
I guess it is just a form of an aperiodic enclosure... a leaky box.
P.S. (edit)
Two more refs.:
- https://www.google.com/patents/US7481295
- https://www.google.com/patents/US3233695
Old 9th February 2014, 09:03 PM   #3
freddi is offline freddi  United States
freddi's Avatar
Merle Haggard - Swingin' Doors (with lyrics) - YouTube
- -"According to my invention, I provide in at least one wall of a totally enclosed cabinet, or bafiie, what might be termed a pressure relief valve one example of which is the formation of an opening or passage in said cabinet communicating with air therein, and supporting within this opening with suitable clearance between its perimeter and the edges of the opening, a freely swingable door. This door should be very light so as to have a minimum of inertia and it is preferably suspended within said opening with non-metallic means."
Old 9th February 2014, 09:48 PM   #4
tca's Avatar
Yes, I know... did anyone try to build one?
Old 10th February 2014, 02:42 AM   #5
Greebster's Avatar
Sounded like a Kazoo
When all your problems look like nails, then the only solution is a different hammer - MLH
Old 10th February 2014, 11:30 AM   #6
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
If the leaking around the flapping part is small the thing is a bass reflex with a passive radiator with a far higher tuning frequency than normal. Otherwise is some kind of amplitude modulated resistive vent.
DIY
go to a fleamarket and buy the cheapest pair of closed boxed you can get.
Cut a large hole on one box
Cut a piece of cardboard slightly smaller than the hole
Suspend the cardboard in the hole.
Play some music and se the cardboard flap around....
Old 10th February 2014, 11:32 AM   #7
xrk971 is offline xrk971  United States
xrk971's Avatar
Maybe it should be called a "Flapping Baffle" (FB)?
Old 11th February 2014, 04:15 AM   #8
freddi's Avatar
fwiw - for cabinets of that era, I like the R-J
EV SP15 in the 15" RJ
Lafayette's "Eliptoflex"
one of my 4 old 18" RJ vent path woofers
Old 11th February 2014, 04:29 AM   #9
freddi's Avatar
here are two papers concerning the R-J
http://downloads.bbc.co.uk/rd/pubs/reports/1955-08.pdf
http://www.jumpjet.info/Pioneering-W...CA/1952-04.pdf
Old 11th February 2014, 04:40 PM   #10
DrBoar's Avatar
There was a swedish company that made similar bass reflex boxes. That is a subbaffle that creates a roughly conical cross section of the vent. Perhaps was the idea that a cicular vent close to the cone would confer some symetric loading? Jamo in Denmark had two concentric tubes outside with the driver in the center. The gap between the tubes formed a vent with a straight cross section around the driver.
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 23 12th February 2013 02:23 AM
Baffle size and shape -> baffle step saschagabor Multi-Way 1 14th December 2010 10:45 AM
Need help designing a new cabinet/baffle with proper driver to baffle placement. Big_Bill Multi-Way 17 16th June 2010 04:34 AM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Finding the perfect open baffle woofer? Albert Multi-Way 8 23rd March 2003 03:48 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
