Mini Posaune
Hello,
i ´ve done the Mini Posaune for 3" fullrange drivers.
Free plan in german but understandable:
Hörner
down 35 Hz, soundstage like a omnidirectional driver, near 90 dB 1 W1m.
how?
two 8 Ohm parallel it is a bipol, in serie it is a dipol and does not work so well,
you can see a few other graphs on the link, but because it is undamped
it it not compairable, look there.
experience and i compair with RDH20 and Bassel with Flute, by test cd´s
the rear driver could be a cheap one, EBP > 120
The mini Posaune is the smallest of five constructions look my HP
Kornett, Posaune
posaune
kornett
No, parallel vs series connection only sets the overall impedance, the polarity of the drivers and how they are mounted make it a bipole or dipole. From your impedence plots it looks like nominal 8 ohms. If two drivers are connected, it would mean they are 4 ohms in series. Since you say it acts like omni, I assume the driver polarity and mounting is such that both cones push out for a positive pulse input? From what I have seen in your past builds, the driver on the back side tends to be mounted with magnet out, so for a bipole, the polarity on rear driver is reversed?
