Effects of extending the baffle
Old 11th January 2014, 03:11 PM   #1
Mixonsr is offline Mixonsr  United States
Mixonsr's Avatar
Default Effects of extending the baffle
I am considering finishing my MK3s with a baffle that will make the speaker flush but also extend the baffle away from the speaker body. I like the look.
I have read that it is not ideal to have an abrupt transition at the baffle. Is there a rule or considerations if I do so.
Old 13th January 2014, 09:31 AM   #2
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
This is a unusual feature, also not looks good.
My preference are rounded corners, in second place wraped the cabinet with 5mm black felt (no wood vaneer or paint) both solutions also are to consider.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 13th January 2014, 04:07 PM   #3
mikejennens is offline mikejennens  United States
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
Some folks use a supra-baffle. Judging by the expertise of some that use them, I'd say you should be OK with one. I don't know about the entire baffle though.
https://www.google.com/search?q=supr...2F%3B638%3B640
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Nola Brio Clones with a Voxel Sub and a bunch of others...
Old 14th January 2014, 08:47 AM   #4
Worth to mention the floating baffle as used by Dynaudio.
Old 16th January 2014, 06:08 PM   #5
chrisb is offline chrisb
Central pair of this group shot is something I've done a few times now with small "supra-baffle" on FH3s - could certainly be applied to other narrow enclosures as well.
Panel on which driver is mounted is extended each side by thickness of one layer of material ( nominally 3/4" - 18mm), and is beveled at 45dg - if material is thick enough, a large radius can work as well, but I like the looks of bevel in this instance.
To allow for swapping of different size / shaped drivers, the removable baffle is attached with machine screws and threaded inserts, and sealed with closed cell foam tape.
Effects of extending the baffleHide this!Advertise here!
4th order Bandpass- Effects of extending port outside of enclosure? treedog Subwoofers 7 17th January 2005 06:27 PM
extending UPS battery Cameron Solid State 19 30th July 2004 09:47 PM
Just how severe are the effects of baffle step? The Paulinator Multi-Way 21 17th November 2003 08:45 AM
Copyright ©1999-2017 diyAudio
