3-4 inch Tang Band in a TL - diyAudio
Old 22nd December 2003, 04:41 PM   #1
fireman is offline fireman  Canada
fireman's Avatar
Default 3-4 inch Tang Band in a TL
I just finished assembling a 1/4 wave TL sub for the living room. I still have a little tweaking to do but already I am very pleased with the result. !
But now I have more and more reserve with my old Toshiba speakers. As a matter of fact, they sound like crap. They have absolutely no highs, the mids are not bad but not exactly lively and the bass is terrible.
The sub has definitely helped a lot with it's tight bass. Now I need something that can replace the Toshibas. I remember first looking at Rob Sampson's web site and finding the concept quite interesting. Unfortunately, I have no clues how to do the calculations to achieve such a project.
My goal would be to use a 3-4 inch Tang Band friver in a configuration that might look something like the Boomtube.
Is this possible ? If so, could someone point me in the right direction in order to find the calculations required to achieve such a design ?
Old 22nd December 2003, 10:54 PM   #2
diyAudio Member RIP
Simple sealed boxes are all you need to integrate with the sub.
sreten.
Old 28th December 2003, 11:35 PM   #3
Timn8ter's Avatar
If you like the Tangband drivers (as I do, especially the W3-871S) I would suggest the following.
For a single driver application see:
http://home.new.rr.com/zaph/audio/audio-speaker11.html
For two driver applications see:
http://www.creativesound.ca/details.php?model=ELF1.5DK
or
http://www.alegriaaudio.com/css_elf_1.htm
For a four driver application see:
http://www.alegriaaudio.com/aural_imaging_isa.htm
I know that many have built Voigt pipes using RS 40-1197s and Fostex FE-103s and that the Tangband W3-871S should be able to work in something similar although I've not actually tried it.
http://www.alegriaaudio.com/bipole_voigt_pipe.htm
http://melhuish.org/audio/DIYTQ3.html
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 6th June 2009 12:37 AM
Exiting new 4 inch FR driver from Tang Band? Fast1one Full Range 1 21st May 2008 08:28 PM
Tang Band MTM ? wrenchone Multi-Way 11 21st November 2007 07:39 PM
Tang Band W1-1070SE - 1 inch transducer with 170 Hz Fs? arjscott Multi-Way 4 17th November 2006 03:51 PM
new 6.5 inch tang band woofer mightyjimbo Multi-Way 6 14th July 2004 11:16 PM
Copyright ©1999-2017 diyAudio
