Why Does It Matter..... - diyAudio
Old 3rd November 2013, 05:47 AM   #1
dklk is offline dklk  United States
Default Why Does It Matter.....
If you use MDF or birch ply if you use damping material to damp the inside any way?.......
Old 3rd November 2013, 10:13 AM   #2
Stuffing doesn't stop panel resonances.
Old 3rd November 2013, 11:55 AM   #3
Philosophil's Avatar
Plywood is stiffer than MDF and this helps lower the amount of damping material needed. Plywood is also lighter, takes screws better than MDF (especially over multiple uses), and is generally more durable.
MDF has it's own virtues, but stiffness is not one of them.
Old 3rd November 2013, 05:14 PM   #4
sippy is offline sippy  United Kingdom
Using the 'search' option will bring you a few results dklk - Plywood v MDF might be a starting point.
Old 4th November 2013, 04:08 PM   #5
chrisb is offline chrisb  Canada
Take a snack, and bathroom break before you sit down to research this one - no shortage of "discussion"
The easiest way to answer the question for yourself might be to build two pairs of the same enclosure design from both - not a desk top mini-monitor, but a full sized MLTL or BLH for example. As I believe I've posted on this topic within only the last week or so, I did exactly that about 10 yrs ago, and have stuck with BB or superior grades of "high density" multi-ply since. And oh yes, not all "multi-plys" are created equal.
... so, not as easy at it sounds, this letting go thing
Old 5th November 2013, 09:32 AM   #6
ODougbo is offline ODougbo  United States
What about a Hybrid box?
1st: Make the interior panels out of 1/2" ply (with internal bracing)
2nd: Laminate 1/2" mdf over the entire box, all 6 sides
Advantages: easy build, can router edges with ease, no end grain and 1" solid walls; certain to pass the knuckle test.
Old 5th November 2013, 08:47 PM   #7
certainly a valid approach, depending on your personal goal for the "knuckle test", but no end/edge "grain" on routed MDF? well, maybe not after several coats of high solid primer /sealer
Old 5th November 2013, 09:09 PM   #8
lanchile's Avatar
The best solution for this is BRACING the cabinets no matter what material you use MDF or Plywood, stuffing cabinets will help for sure, but will not solve problem.
Make it simple...Make it better!
Old 5th November 2013, 09:13 PM   #9
diyAudio Member RIP
FWIW if ply is superior to MDF due to mass versus stiffness
then low grade low density ply used in thicker sections of
less weight will be superior to higher grade plywood.
It won't be as strong, but due to the extra thickness, stiffer.
rgds, sreten.
Old 5th November 2013, 09:38 PM   #10
One more thought about a mix of both; wish I had done this on a few projects. The dowel in the side of mdf ploy doesn't carry very far.
The outside box in sketch is mdf, can build-in plywood "bar -bells" with a few steps, and will help take the ring out of the box.
Size does matter! no gas Tubes / Valves 4 11th December 2010 03:01 PM
Does Efficiency Matter? Patrick Bateman Multi-Way 23 23rd December 2009 10:34 PM
What exactly is beaming and why does it matter? paulspencer Multi-Way 101 13th June 2006 12:29 AM
Does Size Matter sirius98 Multi-Way 11 10th November 2004 04:27 AM
Size does matter.. dutch diy Multi-Way 3 19th July 2001 10:30 PM
Copyright 1999-2017 diyAudio
