An Improved Transmission Line Alignment.
Old 4th October 2013, 04:43 AM   #21
Bjohannesen is offline Bjohannesen  Denmark
I think it is something similar I mentioned in my rules of thumbs above and use in TABAQ.
Old 4th October 2013, 09:30 AM   #22
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Slot vents in themselves are fine.
Damping in an MLTL should not significantly attenuate overall SPLs, nor shift the box gain away from what is intended. If it does, then it's not been designed properly. A well designed cabinet of this kind should not have any issues with harmonic modes.
Old 4th October 2013, 09:32 AM   #23
Scottmoose's Avatar
I seen a topic that I have not seen discussed. That is, the interference nulls created with transmission line type speakers.
As in pipe harmonic modes? It's mentioned in one way or another in just about every QW thread on the forum.
Old 4th October 2013, 02:37 PM   #24
cochleus is offline cochleus  United States
cochleus's Avatar
No, in fact the frequency(s) are exactly between harmonics. If you take a transmission line with a driver at zero position (not offset) a null in the far field occurs at 4 times fundamental (between third and fifth harmonic). This wavelength is the length of the pipe, the pressure wave coming from the vent is 180 out of phase with speaker front wave. If you offset the driver (1/4 wavelength of this frequency from the closed end) the vent pressure sums now to zero at that frequency because you now have two separate pressure waves adding inside the pipe. Therefore, there is no pressure wave coming from the vent to cancel the front wave pressure at that frequency. This nulling occurs at all multiples of this wavelength, but the first (or lowest) is the most serious.
"It always comes down to the best guess..."
Old 4th October 2013, 04:20 PM   #25
cochleus's Avatar
Here's another way this nulling effect could be mitigated: mount a second driver separated by the distance equal to 1/2 wavelength of the frequency to be eliminated (measured inside the pipe), and the internal pressure wave then sums to zero at the vent terminus for that frequency.
Old 4th October 2013, 05:59 PM   #26
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The nulling effect is part of the same issue as the peaks with the same solutions. Take the peaks away the valleys go with.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th October 2013, 01:47 AM   #27
LineSource is offline LineSource  United States
LineSource's Avatar
Originally Posted by Patrick Bateman View Post
There's gotta be a better way to fix the dip, right?
Attached HornResp data comparing SPL response when the speaker is located near bottom of box, and ~32.8% down from top of a quater wave long box. The selection of stuffing material can also shape SPL response and final sonics. Naturally, not all designs permit flexible speaker location options.
What is the best simulator to add port shape modeling?
?Exporting the HornResp model into AkAbak and then extending that AkAbak model to include detailed port models?
Has anyone successfully modeled multiple ports with X,Y,Z dimensions that control resonance and air flow restriction?
Old 7th October 2013, 04:52 AM   #28
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
I have successfully modeled port shapes by approximating a 2 dim port as a series rectangular ports of prescribed dimensions. This is how I modeled the Karlson aperture. See post in the Karlson thread here: Karlson I have also modeled arbitrary ports located at different points along the TL to detune the Q of certain cavity resonance modes. See my thread here: The Flute Pipe TL.
Akabak is very flexible and allows arbitrary xyz (and alpha, theta, phi angular orientation) placement of ports/vents/radiators.
Old 11th October 2013, 04:55 AM   #29
speakerman19422 is offline speakerman19422  United States
speakerman19422's Avatar
Originally Posted by sreten View Post
Then Bud Fried came along with a load of unverified nonsense,
but he made it sound good, which it isn't, and was very influential.
rgds, sreten.
Can you please state which exact Bud Fried T-line speaker models you have heard?
0 Phase Constant Voltage Series Crossovers.
1/4 W T-lines for Satellites and Subwoofers
Old 11th October 2013, 05:32 AM   #30
This might be of some help.
An Improved Transmission Line Alignment.Hide this!Advertise here!
how to combine Line array and transmission line together Jared Multi-Way 7 15th December 2012 01:20 PM
Help with converting sealed box line array loudspeaker to transmission line enclosure jb0194 Multi-Way 3 7th January 2012 05:08 AM
line array + transmission line ? zobsky Multi-Way 12 16th August 2006 04:18 PM
Cartridge alignment in SME 3009 s2 improved - I'm confused! Kuja Analogue Source 3 22nd June 2005 09:44 PM
Transmission Line Alignment Tables MJK Multi-Way 8 19th October 2003 07:06 PM
