Audio Nirvana Classic - diyAudio
Old 1st October 2013, 02:24 PM   #1
Default Audio Nirvana Classic
I am one of the proud new owner of this "whizzer-less" full range driver and have them mounted in a variation of the BK-16 BLH cabinet. I do not have designs to provide, but they were specifically designed for this driver. Bass performance is excellent so far, and highs are filling in nicely, but I would like to implement a Zobel network to compensate for the rising impedance and I have no reliable way to measure the Le parameter accurately. Could this measurement be derived from some other method than direct measurement? Any suggestions on other methods of "taming" the peaky behavior in the 5 Khz-10 Khz range? I have only run them for 100 hours or so, so perhaps this will tame down a bit, but its enough of a distraction for me to warrant a compensation network of some kind.
For those interested in this driver, I can tell you with assurance they are an upgrade to the AN 8" Cast which I currently have as well. They offer a broader and deeper soundstage, better off-axis response, typical AN imaging, with surprisingly solid bass. Detail through the treble is every bit as good as his other offerings. Just has a very different overall presentation and I think most folks will agree that its an improvement and a step in the right direction.
Old 1st October 2013, 03:28 PM   #2
GM is online now GM  United States
GM's Avatar
Without measurements, calculating a zobel can be approximated using the published impedance plot and Re. Can't read the plot clearly, but its inductance rise is very low if accurate, so a zobel wouldn't accomplish enough to justify its insertion losses.
A parallel notch filter is the time honored way to deal with this driver's published break-up modes, though without measurements can be a tedious affair at best: Parallel Notch Filter Designer / Calculator Help
Parallel Notch Fliter Designer / Calculator
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 1st October 2013, 03:35 PM   #3
As I am sure your are aware the plots at CSA are not always the most accurate... What kind of measurements would be helpful in designing a compensation network for this driver?
Old 1st October 2013, 05:57 PM   #4
Scottmoose's Avatar
Ideally on & off axis FR sweeps of the driver on the baffle it's being used with, plus impedance plot[s]. And if you can measure the T/S parameters with low voltage & with more normal loads, so much the better.
Old 2nd October 2013, 01:37 AM   #5
norman bates's Avatar
3khz - 6khz seems to be troublesome on that driver.
Old 2nd October 2013, 03:10 AM   #6
freddi is offline freddi  United States
freddi's Avatar
how's fs and qts vs published spec? AN8 stamped frame was reasonable - AN10 stamped frame was off. The Classic 8 should be nice in a Karlson.
Old 2nd October 2013, 12:05 PM   #7
I really do not take anything significant from the plots on CSA, and my "observations" tell me that the range needing attenuation is a bit higher in the bandwidth.
I was contemplating putting the Wild Burro's I have in a Karlson, but not so sure about this speaker.
Old 2nd October 2013, 08:55 PM   #8
Since an 8" narrows in dispersion (maybe 90 degrees @ 2khz, especially without a whizzer), perhaps sitting up to 45 degrees off axis would smooth it out.
Or try a 10 band eq to see where you want to manipulate the freq response.
Either way, good to hear from someone who has tried this driver.
Norman
Old 4th October 2013, 12:05 PM   #9
I think it has enormous potential and I know room interaction are affecting it a bit. I have EQ'ed the driver with very good success. I was just wondering if there was a more "permanent" solution.
Old 4th October 2013, 02:58 PM   #10
You could always try the enabl technique
Audio Nirvana doubtingthomas Full Range 27 22nd October 2011 09:28 PM
Audio Nirvana: new choices InclinedPlane Full Range 1 9th February 2010 03:43 AM
Audio Nirvana Alnico? kunja Full Range 22 28th July 2009 09:30 PM
Audio Nirvana Andy9485 Multi-Way 6 21st November 2006 11:46 PM
Audio Nirvana - Where Is It? How Do We Get There? Bas Horneman Everything Else 9 25th January 2006 02:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
