Will PM4A/5A extend flat to 100HZ on OB?
Old 25th September 2013, 02:24 PM   #1
wyan is offline wyan
Default Will PM4A/5A extend flat to 100HZ on OB?
I am thinking about building a two-way or three-way open baffle. And I am deciding on the fullrange driver. I may pick supravox 215EXC or Lowther PM4A/5A. The biggest buffle size I can allow is 60CM*130CM.
I am sure 215EXC can easily extend to 100HZ and below. And I have heard only good things about Lowther midrange.
So will a lowther PM4A/5A extend to 100HZ even on a small OB? and How small is too small in this application?
Will you pick supravox or lowther?
Thanks a lot.
(I will use woofer to help below 100HZ)
Old 25th September 2013, 05:02 PM   #2
xrk971 is offline xrk971  United States
xrk971's Avatar
You might want to check out the OB response calculator here:
http://p10hifi.net/TLS/downloads/Xlbaffle.xls.zip
Old 25th September 2013, 05:26 PM   #3
Thanks a lot.
Old 26th September 2013, 10:16 AM   #4
2 picoDumbs is offline 2 picoDumbs  Australia
2 picoDumbs's Avatar
Norman Bates is a fan of the baffle with hinged wings that should work well enough.
Old 26th September 2013, 12:03 PM   #5
Angelm is offline Angelm  Bulgaria
I use Edge software to calculate my baffle with EX3 and auxiliary bass.
Here is one option with wings, 20 and 40 cm.
Old 26th September 2013, 01:37 PM   #6
Thanks a lot, 2Pico and Angelm.
Still need to figure out the exact meaning of all the calculator and graphs but I think the two look good.
Today, I just borrowed a pair of PM6A from a friend and simply connect them to my system without mounting.
The low is lacking, the overall sound is thin and little bit too bright, but then the midrange power is there. When I listen to chorus, it is actually powerful, and overwheming. I sort of understand what is "no turning back". :P
Old 26th September 2013, 02:11 PM   #7
gafhenderson is offline gafhenderson  United Kingdom
I imagine a low QTS driver is always going to sound thin on an open baffle without bass assistance.
All lowthers sound bright to me. Their strengths are 300 to 3khz. After that they get a bit chaotic for me, and below that require some exotic cabinets. Sweet midrange in the lowther thing
Old 26th September 2013, 02:14 PM   #8
Thought so. A woofer seems to be the ticket and it works from so many posts that I have read over the internet.
With 215EX the woofer might be able to get deaper and Lowther is claimed to have the midrange magic.
I will try to audition 215EXC and PM4A/5A and hopefully the answer will be there.
Old 26th September 2013, 02:17 PM   #9
Project 10 : Lowther Open Baffle / Acoustic Elegance H Frame System
Perhaps no quite what you're looked ng for , but might give some inspiration.
Old 26th September 2013, 02:32 PM   #10
Thanks.
Will PM4A/5A extend flat to 100HZ on OB?Hide this!Advertise here!
In room measurments. How flat is flat enough? murphythecat8 Multi-Way 65 30th August 2013 02:42 PM
Flat FR, Flat Power Response, in-phase crossover? RockLeeEV Multi-Way 15 7th February 2012 08:07 PM
Why does the grid extend so far beyond the anode ? yajnaS Tubes / Valves 10 22nd November 2011 11:37 PM
Ports: can they extend outside the cab? Emprov Instruments and Amps 2 19th January 2006 06:06 AM
Help extend the life of my 805's georgehifi Tubes / Valves 5 21st March 2005 11:50 AM
Copyright ©1999-2017 diyAudio
