need help in installing el84 as a phase plug in a 8" Visaton - diyAudio
Old 22nd September 2013, 11:36 PM   #1
Default need help in installing el84 as a phase plug in a 8" Visaton
Hi everyone,
Getting some Visaton 8" Full range drivers and would like to do the Decware thing, where steve used an el84 in the center of a fostex FE206E 8" full range driver. i want to do the same thing, and I have no clue as if the tube is a snug fit, or if anyone has tried this experiment, please share if you have any thoughts and maybe the tube pins, have enough magnetic pull to keep it on the center of the pole piece? or is everything going to have to be taken out under the dust cap? Most appreciative of any suggestions... Pianolydia P.s. a sketch of this installation would be nice!!
PIANOLYDIA
Old 23rd September 2013, 02:15 AM   #2
freddi is offline freddi  United States
freddi's Avatar
maybe epoxy putty around the pins and a steel disc cast into the putty so it would hold tight to the pole piece -?
Old 23rd September 2013, 06:29 PM   #3
frugal-phile(tm)
planet10's Avatar
When we tried this, predating Deckard by some time, the metal pins were sufficient to hold the tube in place. It did not work as well as dedicated plugs.
You want the tube to be nearly the same diameter as the voice coil, EL84 in FE206 is a bad match.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd September 2013, 06:55 PM   #4
chrisb is offline chrisb  Canada
IINM, we tried a single large washer early in our experiments with phase plugs - clay filled caps from MAC lipstick donated by my daughter - and found they weren't as stable or as easy to align as 2 small (#4 or 5) flat head screws in a wood dowel or turned bullet shape.
on hiatus
Old 23rd September 2013, 07:11 PM   #5
frugal-phile(tm)
planet10's Avatar
On phase plugs made with foam ear plugs, with a washer, the magnetic field (i asume) kept pushing the phase plugs over. A magnetic circui with 2 or more separate pieces of metal was stable.
dave
Old 24th September 2013, 04:44 AM   #6
Default Dave, How much are your phase plugs
dave
Seems to me lacquered wood phase plugs would be best! Why would someone use something metal near the pole piece will interfere with phase anomalies coming around the magnetic washer or metal plugs etc, seems to me would mess with the sound, or roll off the highs...cone breakup, your thoughts pianolydia
Old 24th September 2013, 05:17 AM   #7
of the many funky little tricks that mr Deckert has come up with over the past dozen or so years that I've been paying attention, the vacuum tube as phase plug is one I never quite understood
perhaps a joke on the audio nervosa sufferers?
on hiatus
Old 24th September 2013, 06:23 AM   #8
freddi's Avatar
-plus it looks horrible.
Old 24th September 2013, 12:12 PM   #9
IG81 is offline IG81  Canada
IG81's Avatar
Most definitely looks out of place. Kind of an Ultra-Fi chimera.
It is my understanding that the plug should have a profile close to the inverse of the cone/whizzer in any case. It will certain affect the sound of the driver, perhaps in a good way, I can't tell without trying it first, but it'll likely not be technically optimal.
Bert Doppenberg's old acrylic hemi-elliptical slotted phaseplug looked much cooler, though I have no idea it there are merits to it.
IG
Old 24th September 2013, 06:13 PM   #10
mondogenerator's Avatar
Haha seriously?
It would only be cool if the tube was functional, glowing phaseplug integral amplifier....
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Tang band 3" phase plug kctess5 Full Range 0 24th March 2012 08:41 PM
Looking for phase plug ideas for horn loaded 10" and 12" drivers Eva Multi-Way 10 11th December 2011 05:17 PM
RCF 13360051 Phase Plug 10" cabinet ideas? col Multi-Way 0 8th February 2011 03:32 AM
Aura 3"...phase plug? Stocker Full Range 56 16th May 2005 07:00 AM
tangband 3" full range w/ wood phase plug? audiotang Full Range 31 5th May 2005 03:40 PM
Copyright 1999-2017 diyAudio
