Cigar box stereo full range Ideas and more
Old 21st September 2013, 04:14 PM   #1
Rick B is offline Rick B  United States
Default Cigar box stereo full range Ideas and more
Ok I am getting ready to start my first project. I have gotten some great input here and I'm hopeing I get a little more here. I have decided to build a Cigar Box bookshelf stereo. Using 3 boxes one for the amp(undecided) and electronics(mp3 fm tuner modual) If you have suggestions for any of this feel free to chime in. I am here now wanting to know given the small size of a larger size cigar box what full range driver yould you suggest. I believe another gentleman who did this used a tang band. I dont really know the actual volume of a general WOODEN cigar box but I have read around .1cf. I would like the most sound I can get out of this from high to low. I would like some ideas and options as far as pricepoints might go. 1. CHeap but will do a nice job
2. average cost but great performance
3. Very high end but would be amazing to listen too.
Im interested in if any of you think any of the choices you suggest may require any other filtering with the suggested driver.
Last I would like lean towards more efficient drivers where possible. I intend to use a fairly powerful amp (overkill) for this project but I want it to turn heads.
FYI- I intend to put a little fiberglass layering in each box just to support and stiffen them up a bit.
Let the suggestions fly about any aspect you want to chime in on I'm all ears.
Oh ya I should say I believe a driver around 4 or 5 inch would be the limit.
Last edited by Rick B; 21st September 2013 at 04:24 PM. Reason: left somethign out
Old 21st September 2013, 06:26 PM   #2
GM is offline GM  United States
GM's Avatar
Hmm, the old boxes I have are more like ~0.4 ft^3 net, though there are bigger ones. Smaller wooden wine boxes OTOH are ~0.24 ft^3, which should accommodate most smaller drivers.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st September 2013, 06:50 PM   #3
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Little box (~2.8 litre), means a little driver, meaning low efficiency & limited bass. Inexpensive i would suggest the Aura NS3 on sale at Madisound, at the max quality end, either of the MA Alpair 6.2 (paper is my preference). If you add a woofer to the mix, or won't miss bass, the Fostex FF85wk could be considered.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st September 2013, 07:04 PM   #4
el`Ol is offline el`Ol  Germany
Use an exciter for the cigar box.
exciter - Parts Express Ships Fast and Ships Free
If it's not loud enough replace the top of the ciagar box with a HPL decoration board with the same look.
You won't get around hiding a sub somewhere.
Old 22nd September 2013, 04:03 AM   #5
Inductor is offline Inductor  Portugal
Inductor's Avatar
I don't know if you make use of a sub-woofer or not, but that's not (shouldn't be) your first priority.
Only that you can go for a driver with very good low frq. extension or disregard that as a priority.
I'm not sure if you know what a 4" coax Tannoy Mini-Autograph speaker is?! Listen yest? The best speaker you ever heard, possible...
Then I would take this new Ciare driver for a test mule NDPA-5 NEW 2013 EXTENDED RANGE and call a ~3L (net) cigar box it's home in a BR configuration. Needs a 4.4 cm diam. port/22.52 cm length - what is a space rather large for this project, you need to add port vol. + driver to the total net internal.
Other interesting drivers
Audax HM130Z0 Aerogel
Fostex FF85WK 3" Full Range
Faital pro 4" FE32/35
http://www.faitalpro.com/products/fi...atasheet_8.pdf
Last edited by Inductor; 22nd September 2013 at 04:10 AM. Reason: link to Ciare NDPA-5
Old 22nd September 2013, 01:32 PM   #6
Inductor's Avatar
The link for the new Ciare NDPA-5 mentioned above is here.
The Ciare NDPA-4 needs a smaller BR enclosure. Let's simulate an acceptable enclosure as an example:
VB = 1.5 L, FB = 93.0 Hz
Port diameter: 3.8 cm/length: 23.31 cm
Port/Driver Displacement: 1.45 lts
Net internal volume: 2.95 lts
Old 22nd September 2013, 02:07 PM   #7
woody is offline woody
I might be wrong but I believe the famous LS35A had a little 2db hump at about 120hz. This little hump made you feal like the bass responce went lower than it did.
Keeping this in mind looks like the Fatal with it's Fs of 100hz,QTS .6 , VAS .07cubic feet might work verry well in your little boxes.
Old 22nd September 2013, 07:35 PM   #8
Inductor's Avatar
Regarding the interest in the Fostex's, more links below.
http://www.diyaudio.com/forums/full-...ach-other.html
Fostex FF-WK Series Speakers
Fostex FF 105 WK - FULLRANGE
hifisound eShop*-*FOSTEX FF 105 WK - FULLRANGE *A
A simulation with this driver Fostex FF 105 WK can work nice in a BR ~4L but also in a reduced ~3L (FB = 58 Hz) (F3dB 90Hz'ish)
Port diameter: 3.4 cm/length: 23.59 cm
In the form of the 4L BR (net) (F3dB 80Hz'ish):
VB = 4.1 L, FB = 57.9 Hz
Port diameter: 3.4 cm/length: 17.22 cm
The Madisound Speaker Store
Old 22nd September 2013, 08:05 PM   #9
Inductor's Avatar
And nonetheless the extended range high sensitivity (91dB) Scan-Speak 10F driver.
Scanspeak Discovery 10F/4424G
http://www.diyaudio.com/forums/full-...f-4424g00.html
SCANSPEAK 10cm full-range driver - YouTube (video)
Old 23rd September 2013, 02:01 PM   #10
Ok thanks for all that. I should say a sub is a possible option down the road but for now i want the best extended range sound from 1 full range driver in a tiny box. Actually a tri mode configuration was floating around in my head. A few of the drivers mentioned are listed as mid bass not sure if the idea is that it will do the job or would those choices require a tweeter? Thanks and any more input let me know. I will let you know what i decide and what i come up with.
Cigar box stereo full range Ideas and moreHide this!Advertise here!
My first build, Ideas on a Horn/TL full range? malovich Full Range 6 27th November 2012 10:56 PM
Full range in a closed box? Racket Scientist Full Range 4 21st August 2010 05:58 AM
full range box size when using a subwoofer pforeman Full Range 27 22nd March 2009 10:27 AM
Cheap full range drivers in the u.k. Any ideas? filholder Full Range 6 9th December 2006 08:42 PM
Copyright ©1999-2017 diyAudio
