Hook up wire for alpair 10.3 - diyAudio
Old 18th September 2013, 02:22 PM   #1
ebiz80 is offline ebiz80  Canada
Default Hook up wire for alpair 10.3
Hi all,
I'm in the process of building Pensil 10.3. In terms of the internal wire from the speaker to the binding post. What guage of wire are you guys using and what wire do you guys reccomend?
Old 18th September 2013, 05:59 PM   #2
Scottmoose's Avatar
Not much of a big deal; the runs are very short for internal wire so voltage drop is minimal. Something like 20ga should be fine.
Old 18th September 2013, 06:20 PM   #3
frugal-phile(tm)
planet10's Avatar
We use 2 sttands pulled from solid core cat 5 cable -- 24g
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th September 2013, 06:21 PM   #4
chrisb is offline chrisb  Canada
I know, let's start another "wire / cable" thread, some things just never get talked to death
Seriously, we typically use single strands of #24 rescued from CAT5 cable - ( on both sides of the speaker terminals), and if you want to get really carried away, 2 or 3 strands per polarity.
... so, not as easy at it sounds, this letting go thing
Old 18th September 2013, 07:12 PM   #5
Thanks for the quick reply guys. Sorry about another wire/cable thread, but when searching through the forum I couldn't find this topic in specific. Now let me rummage through my box of CAT5 cable (I'm an IT tech) and see what I can find. Now solid or stranded core?... just kidding.
Old 18th September 2013, 07:32 PM   #6
solid core, plenum rated with the teflon insulation is best - if it has the rip cord for easy removal of jacket, your life will be a bit easier
and FWIW, I like to continue the "less metal mass in the signal path" philosophy by using the cheapest plastic nut 5-way binding posts on speaker enclosures, and the budget RadioShack / "Source" RCAs on interconnects.
The Eichmann pods / banana plugs RCAs are wonderful, but can cost more than both the drivers and plywood for a small build, and I know where I want to spend my limited budget.
Old 18th September 2013, 07:59 PM   #7
wily is offline wily  Netherlands
Speaker cable made from braided Cat5
i made these for myself using them with the 10.2.
This is a wonderfull cable and sounds amazing.
higly recomended. Its just some work
Old 19th September 2013, 07:48 PM   #8
Scottmoose's Avatar
I'm not sure I want a wire that sounds of anything.
Alpair 10 vs Alpair 7 - Open baffle with boxed woofer. Passive Xover. TiMBoZ Full Range 58 3rd November 2015 03:07 AM
FS - 4 X Alpair 10 drivers with cabinets, ports and wire Antripodean Swap Meet 1 17th June 2012 04:51 AM
Alpair 12 vs Alpair 10.2 and a little Fostex 166 germpod Full Range 4 28th January 2011 04:19 PM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 12:37 PM
Copyright ©1999-2017 diyAudio
