Howard's FF85wKeN - Page 3 - diyAudio
Old 19th September 2013, 12:27 AM   #21
howardg is offline howardg  United States
hi Chris
Howard, you may remember seeing/hearing the faceted enclosures at Dave's place in August. This was 85WK in a tapered MLTL(?), passive LLXO at 240Hz, to 2 opposing pairs per enclosure of Peerless 830870 midbass. I've been test driving those over the past few weekends, and it's quite amazing how much LF energy 4 of those little Peerless per side can deliver - within sane limits - at least enough in my room to rattle some of the loose ornaments. No doubt a much simpler configuration would work quite well for the bottom.
What type of cabinet design do the Peerless 830870 midbass operate in? An MLTL also?
Old 19th September 2013, 12:31 AM   #22
frugal-phile(tm)
planet10's Avatar
Originally Posted by howardg View Post
Also seems like a super tweeter crossed high might be a great way to go with a nice full range
FF85wk is already a decent super-tweeter.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 19th September 2013, 12:33 AM   #23
frugal-phile(tm)
planet10's Avatar
Originally Posted by chrisb View Post
... the faceted enclosures at Dave's place in August. This was 85WK in a tapered MLTL(?), passive LLXO at 240Hz, to 2 opposing pairs per enclosure of Peerless 830870 midbass.
FF85wKeN in an over-large, "dynamically-shaped" aperiodic TL, and the Peerless in an ML-Voigt.
dave
Old 19th September 2013, 07:53 AM   #24
Scottmoose's Avatar
What does FAST stand for?
It has a couple of definitions, one being the daft 'full range and subwoofer technology.' Where the 'technology' comes in of course is mysterious. 'Full range assisted' is a (marginally) better interpretation. Alternatively, you could just call it, as they always used to be called, 'a two way speaker.' It's one of the classic 2-way types of a large mid-tweet coupled to bass units that was relatively popular until ~the early '60s. Can work very well, like the examples above.
Old 19th September 2013, 05:22 PM   #25
And 2.1 systems with a lowish x-over point would be in a different category I guess? Because the woofer is separate and there is only one?
Old 19th September 2013, 05:27 PM   #26
tuxedocivic's Avatar
xrk971,
I have been thinking along similar lines. tuxedocivic was at DIYFEST with a minidsp that had 4 on-board amp channels and a computer programmable active crossover that retains it's settings when detached from the computer. Can easily hold it in one hand and it sounded great to my quick-listen on unfamiliar speakers.
I have a minidsp also, but that was Kyle. His has the miniamp as well I think. The minidsp is a great way to do this.
Old 19th September 2013, 06:43 PM   #27
Scottmoose's Avatar
Presumably, since they rarely seem to appear under that term. It does need to be very low though to avoid obvious localisation issues.
Old 19th September 2013, 11:53 PM   #28
tuxedocivic,
Sorry for the mistaken identification. You had the sub that I borrowed, but it was Kyle who had his minidsp there. Got it now.
Old 20th September 2013, 12:42 AM   #29
What is low enough?
A full range that is larger than the 85wk would probably be best for a 2.1, unless it is for near field/small room listening only. An 85wk dipole might be gutsy enough for louder listening, but then I suppose that would get really fussy about placement.
How much imaging precision is lost with stacked (2 per side) front facing FF85wk's?
One of the advantages I like about the 2.1, as long as there is a high pass filter on the full range satellites, is that it can play with less distortion at higher SPL than the same full range drivers can when unaided.
Old 20th September 2013, 12:55 AM   #30
Bob Brines's Avatar
This is how I do it. My HT rig is Alpair 7.3's as mains and a Peerless 850146 (10" BR) in the front right corner. My XO is 165Hz, chosen to avoid a room suck-out. (The rears are Fostex FE167E's up-firing in the back corners.) While the XO is technically too high, I haven't found localization to be an issue. In pop music, the bass guitar is typically on the left, so that might be an issue with certain mixes, but classical music usually has the basses on the right. Works out fine.
Bob
Help/advice needed - Howard S2 midbass Blew kirby299 Multi-Way 4 9th January 2013 06:33 PM
Copyright 1999-2017 diyAudio
