The making of: The Two Towers (a 25 driver Full Range line array)
Old 22nd June 2018, 04:12 PM   #4301
wesayso is offline wesayso  Netherlands
wesayso's Avatar
I did get some new measurements done today. I've not been able to squeeze in all of the measurements I wanted to do, but hey, it's a start.
The making of: The Two Towers (a 25 driver Full Range line array)-compare-prediction-jpg
One thing I wanted to check is if the predictions were close to the real life measured results. Meaning I can do some further adjustments off line and still be quite sure the end result will match closely. See the graph above. All traces are presented with a 6 cycle frequency dependent window, the top trace (the prediction from DRC-FIR) is moved up by 5 dB. The bottom traces show 3 separate measurements.
Don't mind the actual curve here, that's my set target from where I begin to adjust with some global EQ.
I'd say the predictability is quite good .
The new amplifier is acting way different than my old one. It results in flat phase with my target file, on both sides of the spectrum.
The making of: The Two Towers (a 25 driver Full Range line array)-comparephase-jpg
This means to get what I want, I will have to change my settings in the target/template. All in all this is quite different from the old Pioneer.
Use Science to design your speakers and they will sound like a piece of Art...
The making of: The Two Towers (a 25 driver Full Range line array)Hide this!Advertise here!
Full range line array inrank Full Range 43 16th November 2017 07:25 AM
Full range line array in a tube carpenter Full Range 44 7th January 2014 02:19 PM
full range driver bipole line array idea. fazman Multi-Way 2 7th January 2006 03:36 PM
full range driver bipole line array idea. fazman Full Range 1 6th January 2006 11:21 AM
Full-range line array? mazeroth Full Range 20 1st November 2004 03:47 PM
