I need some 1" [25mm] diameter port tubes - UK
Old 4th September 2013, 09:02 AM   #1
smallangryboy is offline smallangryboy  United Kingdom
Question I need some 1" [25mm] diameter port tubes - UK
Stupid I know, but I'm looking for a retailer for these:
Port Tube 1" ID x 4" L Flared 260-470
The smallest diameter reflex tubes I can find are 35mm here in the UK. I may have to get them from parts express but would prefer to find a European supplier. I can make my own from black plastic tubing but would prefer the flared end.
Failing that anyone have any they are willing to stuff in a jiffy bag and mail them to me?
Old 4th September 2013, 09:14 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
If you use a cone shaped former to open the end up and boiling/hot water that should form 1" plastic pipe.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 4th September 2013, 09:23 AM   #3
Can you buy formers or would you machine the cone out of MDF?
Old 4th September 2013, 10:24 AM   #5
Oooh so close! Thanks for the links.
Old 6th September 2013, 12:28 PM   #6
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
The one inch bsp stainless pipe i have is 23mm inner diameter. That's what i use when i needed one inch ports, works as good as 25mm as far as you could expect.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 6th September 2013, 01:25 PM   #7
boblamont is offline boblamont  Romania
For one inch, bit of plastic pipe, heat and flare the end with half a sail eyelet or similar, or even cut and build up a former on a broom handle, drop it down onto an inverted funnel, loads of options
Old 6th September 2013, 02:15 PM   #8
I could. Have two 60mm by 23mm stainless ports, well pipe. A bit of work and you could chamfer the inner edge. Being metal they may be a couple of quid UK postage.
PM me if you like.
Old 6th September 2013, 02:50 PM   #9
Colin is offline Colin  United Kingdom
Plastic pipe or (gasp) cardboard tube (not from a loo roll, thank you). Recessed inside the front panel it will be barely visible.
Old 6th September 2013, 03:13 PM   #10
Thank you all for the suggestions. I managed to track down some rigid black PVC pipe at an external diameter of 25mm. I'm also going to experiment with the slightly larger Monacor ports at 29mm
I need some 1" [25mm] diameter port tubes - UKHide this!Advertise here!
port diameter vs port lenght panduro Subwoofers 29 17th October 2012 09:34 PM
Why big port diameter? Jay Multi-Way 22 13th March 2007 11:52 AM
Choosing port diameter. Jeb-D. Multi-Way 8 18th August 2006 06:34 PM
Port Diameter jwatts Subwoofers 18 19th May 2006 11:22 PM
Port Diameter Question BAM Multi-Way 3 14th November 2001 01:19 AM
Copyright ©1999-2017 diyAudio
