Port Question - diyAudio
Old 29th August 2013, 01:30 AM   #1
Default Port Question
I have a question regarding internal port clearances.
Is there a general rule of thumb to follow when it comes to how close a port can be to a rear baffle? If I have a 2" dia flared port that is 1.5" from a rear baffle would that have any negligible effects on tuning or port noise?
I was thinking it may be best to be at least one port diameter away from a wall.
Essentially I have a box that is 8" deep and would like to use a 2" port that is 6.5" long.
Old 29th August 2013, 02:26 AM   #2
xrk971 is offline xrk971  United States
xrk971's Avatar
I think that you want to make sure that the cross sectional area of the port (3.142 sq inches) equals the circumference x the gap between the port and the back wall. The circumference happens to be pi x dia or 3.142 x 2in. Thus the gap is 0.5 inch. So a gap of 1.5 inches is 3x the cross sectional area so you should be fine by a factor of safety of 3. At gap of less than 0.5 in the air would accelerate from the enclosure into the port and make more noise. I think you are safe.
Old 29th August 2013, 01:04 PM   #3
Really? A common rule of thumb, that is successful in practice, is to keep the port end at least one diameter away from the wall.
I was so much older then, I'm younger than that now.
Old 29th August 2013, 04:31 PM   #4
chrisb is offline chrisb  Canada
2" sounds like standard plumbing pipe very commonly used for ports - you can always use elbows to fold the port away from back panel
on hiatus
Old 29th August 2013, 06:09 PM   #5
xrk971's Avatar
The ROT is indeed good as it provides a ~2x margin for the area needed. The minimum area derived by equating the duct CSA to the area formed by the perimeter x gap spacing is really just a restatement of mass conservation assuming in-compressible flow (true for low Mach numbers).
1/4 x pi x D^2 = CSA of round duct
pi x D x L = Area of perimeter against wall formed by gap of dia D and depth L
equate the two, you get :
1/4 x pi x D^2 = pi x D x L
pi cancels, and solve for L you get
L = D/4 as minimum. So for a 2 in dia, the minimum is 0.5 in gap. If you really want to get technical, the flow formed will have a necking called the vena contracta that is about 0.6x the gap so really, to be safe gap should be
L = (1/0.6) x D/4 or
L = 0.42 x D
So setting gap at D is more than 2x the min required and seems like a good ROT to follow. In a pinch you can go to 0.42X the dia and probably be OK - it will look tight to your eyes, but the air flow won't know the difference.
Old 29th August 2013, 07:03 PM   #6
larryldspkr's Avatar
Everything I've seen or read says min. 3 inches! I have used elbows with good results.
Larry
Old 31st August 2013, 02:10 PM   #7
paul burchell's Avatar
We are actually using the purchased 2" pipe with the flair on both ends, does that mean i don,t have to use the inner flaired end, to increase the distance from the end to the baffle
ps the port is in the rear baffle
Old 31st August 2013, 02:17 PM   #8
xrk971's Avatar
The flare significantly reduces the pressure losses in the tube and will require the port length to be longer than for an equivalent non flared port - if you want the tuning to be what you think it is with a straight tube. The flare reduces port noise though. If your box design program accounts for flared ports then use it.
port question WaVeInFoRm Multi-Way 78 9th May 2012 11:47 AM
Question considering port length cumesoftware Multi-Way 3 21st May 2008 11:46 AM
port question phillfyspoon Subwoofers 8 3rd March 2006 04:39 PM
Port question? mace Subwoofers 6 10th December 2004 12:21 AM
Port length question masterp2 Multi-Way 40 12th February 2003 02:39 PM
Copyright 1999-2017 diyAudio
