WTD: 100mm Suggestions for BOSE 101 FR Driver Swap - diyAudio
Old 26th August 2013, 05:20 PM   #1
speaker is offline speaker  United States
speaker's Avatar
Question WTD: 100mm Suggestions for BOSE 101 FR Driver Swap
I picked up a set of Bose 101 cabinets recently with blown drivers. There is enough space on the baffle to fit a ~100mm 4-hole driver chassis. Any suggestions on a FR that might work in ~0.22-0.25cF vented enclosure?
Old 26th August 2013, 06:37 PM   #2
xrk971 is online now xrk971  United States
xrk971's Avatar
Try TB W4-1320sif.
Old 28th August 2013, 01:53 PM   #3
speaker's Avatar
Originally Posted by xrk971 View Post
Try TB W4-1320sif.
Thanks but it looks like that one might be too big to fit without cutting up the port tube outlets.
Any other suggestions for an eared chassis design?
Old 6th June 2014, 01:13 PM   #4
speaker's Avatar
No other suggestions?
Old 6th June 2014, 02:17 PM   #5
xrk971's Avatar
Faital Pro 4FE32 (mid Q)
Visaton FR10 or FRS10
If TB 4 in frames are too big try 3 in
TB W3-315e for example
Old 6th June 2014, 03:16 PM   #6
Panasonic Alt 4" Fit Bose 901 101 151 802 402 Fullrange | eBay
Old 6th June 2014, 08:45 PM   #7
speaker's Avatar
Perfect!
FR driver suggestions for HT line array Henkjan Full Range 16 20th February 2012 01:42 AM
FR driver suggestions for PE .25cf cab? toobhed Full Range 18 9th December 2011 04:02 AM
Not quite FR, but a FR driver does most ~ A tower of power with balls (spheres) TimboinOz Full Range 3 28th October 2011 09:22 AM
Fidelity Research FR-101 Stuey Analogue Source 2 1st June 2007 09:59 AM
Bose 85mm fr speakers on ebay, good deal? vinnie Full Range 2 24th January 2007 01:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
