Markaudio Alpair 10.3 OB with H-frame Eminence
Old 28th October 2013, 01:04 AM   #11
danvprod is offline danvprod
danvprod's Avatar
Here is the in-room response 1/6 octave smoothed. Sounds pretty good. I'd like the take these out to measure outdoors, I'd still like to deal with the dipole peak and rolloff, as well as any other anomalies.
I did add a couple of things to the Mini DSP Crossover -- first I added some delay to the LF driver using the out-of-phase null method (i.e. flip the phase of the LF driver in the MiniDSP program and adjust the delay until you get the biggest null at the X-over point), then flip the phase back. The drivers are time-aligned. I dropped the HF response a bit using a -1.5 db 1.5kHz shelving low-pass filter. Also did a broad -4 dB peak filter at 60 Hz (as you can see I have quite a bit of bass build up in my listening room). Also added back in my 25 Hz Q 2.2 peak filter to extended the low bass a bit.
Here is the response in-room. Since, I often listen at pretty low volumes, I don't mind the extra bass response. It sounds pretty balanced to my ears. I am getting nice summing at the x-over point, which is what I want.
Old 6th December 2015, 02:27 PM   #12
Bigun is offline Bigun  Canada
Bigun's Avatar
Hi Dan - it's been awhile and I bet you've done quite a few experiments since you posted this - would be interested to hear about your experiences and advice based on what you have learned about OB ??
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Markaudio Alpair 10.3 OB with H-frame EminenceHide this!Advertise here!
Markaudio Alpair 10 Bass Wide Drivers Musik007 Twin Audio 8 25th May 2016 07:21 PM
HT Front Stage Designs Using Markaudio Alpair 10.2 - Plans, Feedback and Build Log Ben_Tech Full Range 96 2nd January 2015 12:41 AM
Tang Band W8-1808 / TB ribbon tweeter / Eminence Alpha 15A in OB with U-frame superlian Full Range 3 4th September 2011 12:11 AM
FS: MarkAudio Alpair 10.2 Full-Range drivers nar93da Swap Meet 4 7th August 2011 10:36 PM
Markaudio's Alpair 10, German test and review mightyd Full Range 9 23rd April 2009 09:18 AM
Copyright ©1999-2017 diyAudio
