Voigt Corner Horn contemporary build based on original design and materials
Old 7th April 2014, 06:33 PM   #21
Bigun is offline Bigun  Canada
Bigun's Avatar
When I said 'corner horn' above, I meant something specifically designed to sit flush/tight into the corner, sorry if I wasn't specific. I can see why one has to be careful about the use of the term though, it hadn't crossed my mind that it equally refers to horns like the FH3 which do benefit from placement near the walls.
Anyhow, the Decware corner horn was the other one I remember looking at, I don't see many people building it. It was popular half a dozen years ago. Maybe it's not that good, or the fact that the plans are not free have killed it off. The horn that is the subject of this thread looks like it would be very difficult to construct without some further innovation - I could see perhaps that some compromises might be made which would make it easier to build, such as...
Instead of concrete use plywood, built up in thickness
Instead of plaster curves, approximate with plywood
With some changes like this the design could have some real 'legs' in DIY circles.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 8th April 2014, 12:21 AM   #22
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Don't forget that Voigt had some specific needs for this design; it is a compound horn (with indirect radiation from the front of the driver at that), not a back-load like the Decware when used with a wideband driver. Recording BWs at the time & playback devices were much more limited than they are now; the drivers employed also had considerable peaking at the upper end of their operative BW, hence indirect loading of the front was beneficial in helping to attenuate this somewhat. And so on. The same peaking through that region is a continuing trait in some current Lowthers & has become something of a defining characteristic, for better or worse. The irony being that used as intended, in horn such as the one described here, there wouldn't be much left. It's only when you get the direct radiation off the driver that it becomes so apparent.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 8th April 2014, 01:03 AM   #23
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Klipschorn
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th April 2014, 11:37 AM   #24
KLBIrd is offline KLBIrd  United States
KLBIrd's Avatar
A truly great example of engineering and craftmanship. No doubt Mr. Voigt would have been well pleased with your efforts.
Old 15th April 2014, 06:30 AM   #25
Dennis Rech is offline Dennis Rech  United States
The only other corner horn I've seen is the Decware, which looks MUCH easier to build - how do these two compare with each other ?
Hello Bigun,
I combined two of your questions into one comment.
Having built a set of Decware corner horns, I am pretty sure that they ARE much easier to build than the Voigts. No concrete, no plaster (although a bit of Bondo) amd no curved panels.
The narrative mentions having 330 construction hours in the pair.
I had about 40 hours into my two Decware horns built to rather industrial standards, not cabinet maker quality. A friend built his own set after hearing mine. His are solid ash lumber to match the flooring and cabinets in his house. They are gorgeous.
The sound quality is excellent. I have had about 100 hi-fidelity people stop by to listen to mine. Most have said that they are the cleanest sounding speakers that they have ever heard.
I was contacted by a man who read one of my earlier postings. He had inherited a set of Klipse corner horns and had questions about setting them up, so I visited him and he visited me and we compared our systems.
What a difference! About the only thing that the two types of speakers had in common was that they were both big and sat in corners.
The Klipse are powerful. They have big heavy bass speakers and they sound HEAVY. Really heavy.
The Decs have little 6 inch round banana skin cones that sounds like they are directly coupled to the phonograph needle.
Think sport bike vs Winnebago.
Think Bambi vs Godzilla.
It would be interesting to know how the Voigt's compare.
Why aren't there more Dec's built or any other corner horns built?
They are big and need corners and they weigh a lot, more than 100 pounds each.
They are hard to assemble with all the steep angle cuts required and if you have large hands, you may not be able to build them. It's tight in there.
DecWare had the factory versions listed at $3500. I doubt that they could build them for that.
I had $350 in mine including Fostex's.
I have had a long time fascination with horns. I have listened to quite a number of them, built various types and helped build others.
The one thing that is important is that they are big. It is just physics. To get low frequencies out of them they need a large mouth area. Even in corners, they need at least a dozen square feet to get down to 50 hz.
I have not heard a Voigt, but at least it is big enough to function correctly.
And they are beautiful.
Old 15th April 2014, 10:38 AM   #26
Scottmoose's Avatar
Actually they don't need that much terminus area to go low per se. LF cutoff is a function of axial length & to an extent flare frequency. They do need to be large to be impedance matched down to low frequencies & provide a linear response however.
Old 15th April 2014, 12:51 PM   #27
Squeak is offline Squeak  Denmark
Squeak's Avatar
This thread makes me wonder if it would be possible to make a simplified version of the DCH?
Doing a front loaded horn for most of frequencyrange and with omni characteristics, seems an overlooked and interesting prospect.
Sans the concrete thingy, curved tractrix and plaster reflector there isn't much in it that you wouldn't be able to do with plain straight plywood.
- Use an up-firing driver instead of the concrete reflector chamber.
- Use two pieces of ply at a 90 to 60 degrees angle and again this angled piece slanted at 45 degrees above the horn. This would go ca. 90 percent of the way towards the plaster reflector.
- Linear horn, maybe with a karlson slot or holes to simulate a more tractrix-like or exponential expansion.
The horn could be triangular in x-section to be more friendly to midrange and highs and fit in the corner.
With a modern driver I think this would get you something close to or maybe even better than the original design.
Old 15th April 2014, 01:55 PM   #28
Scottmoose's Avatar
Chances are you'll need a unit with a rising HF response given the indirect nature of the driver loading the front horn. No reason why you couldn't do something along those lines in principle though.
Voigt Corner Horn contemporary build based on original design and materialsHide this!Advertise here!
This corner horn design rings a bell - but where? What is it? David Pinnegar Full Range 2 9th January 2011 11:17 PM
Built some Voigt-based speakers with the help of a friend! deltavektor Full Range 8 4th July 2010 08:50 AM
Corner loaded fe127en based speakers? mantisory Full Range 7 25th June 2010 01:32 PM
The Aries15 -a dual horn design original djfoundation Subwoofers 13 10th February 2010 02:03 AM
CSH-horn design/build instructions ingvar ahlberg Multi-Way 1 9th April 2008 08:00 PM
