Voigt Corner Horn contemporary build based on original design and materials - Page 2 - diyAudio
Old 30th August 2013, 10:09 AM   #11
Hello, I'm back from salt mines! Ever since I first read of the Voigt corner horns in a article published in Speaker Builder in the 80's I have looked for plans for this design. It would be a interesting project. Anyone uncover the construction details?
Old 30th August 2013, 04:10 PM   #12
devilsindetails's Avatar
My understanding is that the builders are making the plans freely available, according to the article.
"A problem left to itself dries up or goes rotten. But fertilize a problem with a solution--you'll hatch out dozens." (N.F.Simpson)
Old 31st August 2013, 08:55 AM   #13
Scottmoose's Avatar
That'd be the first time in ~60 years then. Very good of them.
Old 31st August 2013, 09:11 AM   #14
Ivo is offline Ivo  Netherlands
I'd love plans of the Home Constructors Horn as well. A lot easier, I bet.
We want to be happy, bold and free
Old 19th January 2014, 10:18 AM   #15
Do you know if the plans are available yet?
Old 19th January 2014, 03:42 PM   #16
These fellows, Peter Skinner, David Watson et-al, are on your side of the pond from what I remember. Here are my links to contemporary articles on the construction of the Voight Corner Horn.
Apparently the plans are not, yet, available.
retro vintage modern hi-fi: Secrets of the Voigt Speaker - By Peter Skinner
retro vintage modern hi-fi: 1930's Voigt Corner Horn Reflector Reproductions
Old 22nd January 2014, 08:27 AM   #17
lorienblack's Avatar
I would like to add my vote for a set of plans, could not afford to commission a build. But would love to take the project on
Old 7th April 2014, 01:08 AM   #18
Chilli is offline Chilli  New Zealand
I'd be keen on plans as well. Commissioning a build would be cost prohibitive. Perhaps a small fee for the plans.
Old 7th April 2014, 03:13 PM   #19
Bigun is offline Bigun  Canada
Bigun's Avatar
The only other corner horn I've seen is the Decware, which looks MUCH easier to build - how do these two compare with each other ?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 7th April 2014, 03:41 PM   #20
Scottmoose's Avatar
Really? FH3 (and the original FH) is a corner horn. As is Ed Schilling's Hornshoppe Horn, the Buschorns, most of my commercial boxes, several of the Tannoy GRF designs, several Klipschorns & many, many others. A corner horn is not defined by whether the cabinet is designed to physically fit flush into a corner but by whether the horn is designed to use the 1/8 space boundary condition.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
This corner horn design rings a bell - but where? What is it? David Pinnegar Full Range 2 9th January 2011 11:17 PM
Built some Voigt-based speakers with the help of a friend! deltavektor Full Range 8 4th July 2010 08:50 AM
Corner loaded fe127en based speakers? mantisory Full Range 7 25th June 2010 01:32 PM
The Aries15 -a dual horn design original djfoundation Subwoofers 13 10th February 2010 02:03 AM
CSH-horn design/build instructions ingvar ahlberg Multi-Way 1 9th April 2008 08:00 PM
Copyright 1999-2017 diyAudio
