8"woof with 3" xo---is this a tree i should not be barking up?
Old 8th August 2013, 04:14 PM   #1
osd1 is offline osd1  Canada
Default 8"woof with 3" xo---is this a tree i should not be barking up?
hey now
i started a new thread based on an idea i got from a member vix on m fostex thread.
a 8" woofer with a 3" or 4" fullranger sealed in its own box.
i've always wanted to try this woofer because i have had great luck with visaton in the past:
Visaton W200S-8 8" Woofer with Treated Paper Cone 8 Ohm 292-572
if i used that woofer in a ported box or small mltl with a properly designed xo going to a fullrange (vix said something like a 1st order 300-400hz) in its own sealed box, would that work? if its a matter of experimenting with a 1st order xo, that i can do. changing a cap to see if something sounds better isnt that big of a deal. but anything more complicated than that is gonna be a pain because as i always say im no audio engineer.
the visaton b80 looks like such a good little 3" fullranger to accompany that particular woofer. plus skys the limit with lots of offerings from fostex, mark audio and many others for a 3" or 4" full ranger
Old 8th August 2013, 04:16 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Great idea, gaining popularity by the day.
planet10 needs your help:
Let's help Ruth and Dave
Old 8th August 2013, 04:31 PM   #3
chrisb is offline chrisb
check out the Tysen thread of a few years back (Fostex FF85K & CSS SDX7) but the same architecture could apply to a wide range of candidates.
active bi-amping can simplify things considerably, and with the wide availability of media players with reasonable XO functions, particularly easy with computer based music systems
Old 8th August 2013, 04:40 PM   #4
im trying to stay away from computers. id get a behringer dcx2496 for an active xo
Old 8th August 2013, 04:49 PM   #5
Vix is offline Vix  Yugoslavia
Vix's Avatar
Hi! The idea is not mine, all credit goes to Dave (planet 10). Search for F.A.S.T. on this forum, you will find some good examples. So, I proposed that because I tried something similar and was pleasantly surprised. Some years ago I had built ML TL with Fostex Fe206e. Not bad, but had to apply a lot of EQ, also the top end of 206 never really pleased me. ML-TL have the advantage of low footprint (can be skinny and tall, but not too tall) and can go quite low. While it is not an optimal box for 206 you could find the right woofer for it. On the other hand , lately I have become to like the mid and top of some 3-4" fullragers, (oh,but they don't do any bass). Then, I stumbled upon Dave's idea of FAST and...click! It works, but you have to find the right combination. Perhaps others will give you better info, but I'd say that it's the way to go
Old 8th August 2013, 05:33 PM   #6
tried doing a search, couldnt find anything
Old 8th August 2013, 06:08 PM   #7
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
DCX2496 needs lots of work on the analog sections before being usable in any hifi a human wants to listen to. Excellent flexinility filter-wise thou. We try to sticj to simple PLLXOs or 1st order series (latter more expensive and harder to get right).
FAST is not my idea, but we have been promoting the idea as it is an excellent one.
At the upcoming diyFEST we will have 3 new FASTs. An MTM standmount with FF85 and Silver Flute W14, FF85 with 4 Peerless 830870, and Alpair 7.3 with 2 SDX7. + 2 miniOnken with woofTs that have been around for awhile.
Really? Some of the results from a quick search:
A thread for Tysen and variations on FAST
http://www.diyaudio.com/forums/full-...e-article.html
Tysen Variation FE167E with CSS SDX7
Cheap Version of the famous Tysen speaker.
FAST Speaker Design
http://www.diyaudio.com/forums/full-...-possible.html
http://www.diyaudio.com/forums/marka...0-3-build.html
Baffle step correction in a FAST 2way
http://www.diyaudio.com/forums/full-...subwoofer.html
http://www.diyaudio.com/forums/full-...lly-rocks.html
http://www.diyaudio.com/forums/marka...ons-asked.html
http://www.diyaudio.com/forums/full-...st-budget.html
FAST woofer choice for Alpair 7.3
http://www.diyaudio.com/forums/full-...ices-fast.html
Advice for FAST with alpair 7
http://www.diyaudio.com/forums/full-...st-system.html
http://www.diyaudio.com/forums/full-...hing-like.html
Tangband w3-871sc and Dayton DC200-8 in a FAST System
FAST-ish enclosure help.
http://www.diyaudio.com/forums/full-...uild-fast.html
Alpair 6p FAST
http://www.diyaudio.com/forums/marka...12-woofer.html
FAST build with Alpair 7.3 and Seas L26ROY and Hypex AS2.100
Bi amped FAST design, active crossover
http://www.diyaudio.com/forums/full-...ast-f-s-t.html
FAST with Feastrex D9NF and Fertin 38EX
5-1/2", 6-1/2" or 7" woofer for FAST desktop?
http://www.diyaudio.com/forums/full-...iver-fast.html
http://www.diyaudio.com/forums/marka...as-l26roy.html
http://www.diyaudio.com/forums/full-...part-fast.html
http://www.diyaudio.com/forums/multi...st-design.html
FAST woofer rec for 6 liter enclosure
http://www.diyaudio.com/forums/marka...a-drivers.html
FAST with Alpair 7.3, Trio8 and MiniDSP.
Tang Band W8-1808 in a bi-amped FAST
http://www.diyaudio.com/forums/full-...ld-you-do.html
http://www.diyaudio.com/forums/marka...l-tl-fast.html
http://www.diyaudio.com/forums/full-...-way-fast.html
FAST: Aperiodic or Folded TQWT
http://www.diyaudio.com/forums/marka...prototype.html
http://www.diyaudio.com/forums/marka...rossovers.html
http://www.diyaudio.com/forums/marka...lp-needed.html
http://www.diyaudio.com/forums/marka...er-6-fast.html
http://www.diyaudio.com/forums/full-...sque-2way.html
http://www.diyaudio.com/forums/full-...uld-i-use.html
looking for effecient 4" driver for FAST system
http://www.diyaudio.com/forums/multi...op-system.html
http://www.diyaudio.com/forums/marka...st-system.html
http://www.diyaudio.com/forums/marka...t-alpairs.html
http://www.diyaudio.com/forums/full-...0-my-fast.html
OB woofer (FAST) for tube amps
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 8th August 2013, 06:56 PM   #8
Well, the DSP processor inside that box is a computer of sorts, and frankly not the best sounding example of this class, but that's another pizzing contest
If you don't need all the flexibility of such a device, then a very cheap and simple passive line level XO can work like a charm. Their disadvantages are lack of adjustability on the fly, need to include the input impedance of amplifiers driving each speaker in the calculus, and no flashing lights or other bells and whistles.
Old 8th August 2013, 07:02 PM   #9
i think im just gonna make the tysen's. unless i can find another kit thats around the same size.
Old 8th August 2013, 07:07 PM   #10
frugal-phile(tm)
planet10's Avatar
Neither of the drivers in Tysen are readily available. The newer FF85 is, we feel, an upgrade, a sub for the SDX7 is harder, but there is lots of choice to pour thru.
dave
8"woof with 3" xo---is this a tree i should not be barking up?Hide this!Advertise here!
Rock and Roll speakers, is a Chebyshev bass XO going to give more "Kick"?? Moondog55 Multi-Way 11 18th July 2012 05:34 AM
DCX2496 "extra" settings to improve XO designed with it? doug20 Digital Line Level 4 4th May 2010 04:58 PM
Latest project, 3 way with 10" sealed woof Nortp Multi-Way 9 17th August 2007 01:15 PM
3 way - how to measure woof/mid xo point? Dave Bullet Multi-Way 7 22nd June 2007 06:29 PM
Best 10" woof Question apassgear Multi-Way 5 4th April 2003 08:52 PM
Copyright ©1999-2017 diyAudio
