New PHY-HP E17 LB 15 - diyAudio
Old 7th August 2013, 11:16 AM   #1
Elias is offline Elias  Finland
Elias's Avatar
Question New PHY-HP E17 LB 15
Looks like the long waited 6" PHY-HP ferrite driver is available
e17lb15
Not as beautiful as other PHY-HP drivers, but a lot cheaper. This could be interesting, but the specs are sparse.
Who has tried these ?
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 7th August 2013, 11:19 AM   #2
Elias's Avatar
From the PHY-HP site, there is this DIY speaker
From the design of the round oven, I would say this is Scandinavian based
Old 16th August 2013, 04:02 AM   #3
norman bates's Avatar
I think we were waiting for a reasonably priced ferite version of the 12", with or without tweeter...........
12" are around 2k each (U.S. dollars) I think.
Old 17th August 2013, 09:24 PM   #4
here is links to them on youtube.
https://www.youtube.com/watch?v=wvf7rDcNfVU
https://www.youtube.com/watch?v=9eGGi12W6AU
phy website.
index
those 6" seem to be $400 each (U.S. dollars) and in stock.
Rereading Bernard's review on 6moons, he really went back to the original ways of making paper cone drivers.
6moons industryfeatures: Bernard Salabert of PHY-HP
"Music, on average, is a mix of 30% sinusoid and 70% very steep short signals (impulses, transients and such). If a sinusoidal wave is easily reproduced, transient spikes are far more difficult to render properly. For that the mobile equipment (cone + spider + leads + voice coil) should have an infinite slew rate i.e. zero mass. That's impossible of course but you must come as close as possible to 0. You need a very light cone that is rigid enough and features progressive fracturization in an hyperbolic-exponential profile. Only paper with long and short fibers can accomplish that, plush a small-diameter voice coil where one layer is inside and one outside of the former to transmit the movements of the coil with the fewest possible losses (I use impregnated vellum). It is simply in respect to basic PHYsical laws that I made these choices, not to return to the roots per se. But surely it is not a random coincidence that people from the 30s to 70s made drivers like this. They were not stupid as it seems a lot of people today like to believe. These physical laws haven't changed. Obeying them once again not only makes for better drive units, it is also a very nice way to keep alive the knowledge about these technical matters."
Norman
Old 17th August 2013, 10:11 PM   #5
Elias's Avatar
I also wish they would make a 12" version using the bronze basket but with ferrite magnet. Removing AlNiCo would lower the price. 1375 for one driver is too much for 'normal' people...
It's good to have dreams Life goes on
Old 11th September 2013, 09:37 AM   #6
graaf is offline graaf  Poland
graaf's Avatar
"Music, on average, is a mix of 30% sinusoid and 70% very steep short signals (impulses, transients and such). If a sinusoidal wave is easily reproduced, transient spikes are far more difficult to render properly. For that the mobile equipment (cone + spider + leads + voice coil) should have an infinite slew rate i.e. zero mass. That's impossible of course but you must come as close as possible to 0. You need a very light cone that is rigid enough and features progressive fracturization in an hyperbolic-exponential profile. Only paper with long and short fibers can accomplish that, plush a small-diameter voice coil where one layer is inside and one outside of the former to transmit the movements of the coil with the fewest possible losses (I use impregnated vellum). It is simply in respect to basic PHYsical laws that I made these choices"
not really only
basic physical laws say that there are much better ways to come as close as possible to 0:
200 x 2" drivers What to do?
"high phooey and hystereo" - Yascha Heifetz
Improving my Phy-Hp drivers Sjef Full Range 26 18th November 2007 08:07 PM
PHY-HP Drivers mark02131 Full Range 2 25th November 2006 07:06 PM
Phy-HP crossover network HELP!!!!! mmolina Multi-Way 1 13th December 2004 03:51 AM
FS: Phy-Hp tweeters Sjef Swap Meet 2 29th October 2004 08:33 PM
Suggestion for PHY-HP KM30 enclosure cmt42001 Multi-Way 3 26th March 2004 11:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
