Fostex FE206: recommended or BK208 enclosure? - diyAudio
Old 5th August 2013, 01:38 PM   #1
Default Fostex FE206: recommended or BK208 enclosure?
Hello,
I want to build some new loudpeakers with the Fostex FE206en. They should be easiliy to build.
So I came across the 206 recommended and the BK208 chassis. Which one would you prefer and are some other enclosure plans out there which can be made as easily as the mentioned ones and get better results in music reproduction?
Many thanks,
Rents
Old 5th August 2013, 02:04 PM   #2
Scottmoose's Avatar
As far as I am aware, the 'BK 208' is actually Fostex's Factory design for the FE208ESigma:
http://www.fostexinternational.com/d...ez_enclrev.pdf
Of the two boxes, I would be inclined toward the 208 cabinet; it should produce somewhat more gain & a better balanced response than the 206 box -I've never liked the stock E / En (they didn't change them when the new drivers were released) designs all that much. LF gain isn't much to write home about with them, & there's an unpleasantly deep notch at F3 that's a bit of a pain to fix.
Old 5th August 2013, 05:56 PM   #3
zman01 is online now zman01  Bangladesh
Renton76,
If you do not object to tall enclosures and have the space, you can take a look at Scott's designs for the FE206En like the Kirishima. Then he has a design called the Vulcan.
The FE208E Sigma cabinet that Scott has linked above is a good one for the FE206En, but lot of pieces to put together. Probably the taller Kirishima or Vulcan would be a simpler build and possibly require less ply.
Old 5th August 2013, 07:52 PM   #4
frugal-phile(tm)
planet10's Avatar
or Dallas II
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th August 2013, 09:50 PM   #5
DrBoar is offline DrBoar  Sweden
DrBoar's Avatar
Side Vivace that is an adaption of the Schmacks horn or the Big Fun horn if you have the space and the desire to get bass below 50-60 Hz.
Old 6th August 2013, 09:00 AM   #6
hm is offline hm  Europe
hm's Avatar
Default renton
Hello,
look my solutions for Fe206 and others:
http://www.hm-moreart.de
Fostex FE126E Recommended Enclosure CastleJohn Full Range 16 13th January 2011 08:45 PM
Fostex recommended enclosure (F200A) LageB Full Range 3 18th July 2009 09:56 AM
Fostex recommended FE103 Enclosure Rega Full Range 27 12th January 2008 07:59 AM
Trouble Reading Blueprints For Fostex Recommended Enclosure kelticwizard Multi-Way 2 13th April 2007 04:18 AM
Fostex FE108EZ recommended enclosure hkoetz Full Range 3 23rd November 2003 12:42 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
