Is a cross-over required in full-range speakers? - diyAudio
Old 26th July 2013, 08:10 AM   #1
Default Is a cross-over required in full-range speakers?
Dear Audio experts,
I am a audio newbie who got interested in audio recently. May I ask whether a crossover is required for full-range speakers? My guess is that it is not required because a full-range is just a single speaker covering the entire frequency range. There is no twitter, sub-woofer. Correct me if I am wrong.
Thank you.
Old 26th July 2013, 08:26 AM   #2
frugal-phile(tm)
planet10's Avatar
Crossover not required, sometimes a filter is useful thou.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th July 2013, 05:35 PM   #3
Inductor's Avatar
helpme,
You might want to know that your driver it's the same (acoustic/electric parameters) as it's equivalent circuit.
You can make 2-way speakers with minimal crossovers with no practical advantage for the no-crossover speaker, in such a way. Also the frequency of the crossover plays a major role on it's problematics with vocals and others. The same with the phase, very important for accurate reproduction and localization of the source. In a multi-way also the good qualities of a fullrange are looked in for the mid, if we can say so, comparing it in that way.
But you are right the short answer is no.
http://www.scan-speak.dk/datasheet/pdf/10f-4424g00.pdf
NEXT-proaudio Portugal
Old 26th July 2013, 06:01 PM   #4
expert in tautology
bear's Avatar
What dave was saying is that a "filter" circuit is sometimes used to correct for non-flat anomalies in the "full range" speaker's response.
Having said that, it is good to realize that most "full range" speakers are in fact somewhat less than ideally full range, especially in the LF. However there are some clever loading (box designs) methods that can make them surprisingly respectable, albeit at moderate SPLs.
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- [...2SJ74 Toshiba bogus asian parts - beware! ]
Old 26th July 2013, 06:56 PM   #5
chrisb is offline chrisb  Canada
FWIW, in my personal lexicon, a "full range" driver is one that is operated without bandpass filtering - but that may include active or passive circuits for EQ / shaping / impedance compensation whatever you care to call it.
Depending on exactly what your definition is for "full audio range", there are certainly few, if any, single driver systems that would objectively meet the criteria - but many that can be more than musically satisfying when used within their limits. Once you add supporting woofers / super tweeters with separate filters and/or amplifiers, you're really operating a multi-way.
now on sabbatical
Old 29th July 2013, 01:14 PM   #6
Sometimes to carefully limit a speaker where it's useful response ends is an idea . It could help power handling and lower distortion . If a bit of resistance is added or a choke more might be gained than lost . Playing LP records especailly ( warps ) can be a problem .
I have been trying to work out the inductance of cheap 500 g reels of copper wire . I suspect these might make sensible chokes at low cost . Plastic reels if so . Often the start wire is available to use .
For protective filtering a non polar cap might be used as a quick check . 220 uF 35 V x 5 is circa 20 Hz 8 ohms ( parallel ) . They might sound better than many think and offer simple DC protection . Far better than a fuse . 35 V should be OK .
220uf 35v Non Polarised Capacitor.
Old 29th July 2013, 04:18 PM   #7
expert in tautology
bear's Avatar
Nigel, it is easier to simply measure the inductance rather than calculate it. One can approximate an actual measurement by using a scope, resistor (load) and a signal generator, just look at the -3dB point. Easier still if you have known inductors to compare with.
Otoh, my DVM has an inductance measuring range on it.
_-_-
_-_-bear
Old 29th July 2013, 05:07 PM   #8
That's what I meant to say . Work out was more like listing . I fancy to buy an inductance meter as it saves time .
I saw one in Maplin in UK . Surprisingly they are less common than I thought . Maplin is usually a bit expensive ( $70 ) . I don't care about accuracy as I have chokes to indicate the trends . Hope the listing is OK below , previous would not open .
http://www.amazon.co.uk/HQRP-3-Funct...ductance+meter
As the links failed this is what you would see . $30 . Seems very good if spec is met .
Old 29th July 2013, 10:01 PM   #9
Sorry Help me 54 I don't know your name . I have just bought a pair of these ( 12LTa in fact ) .
BETA 12LT - EMINENCE - EMINENCE BETA-12LT 12" 225W TWIN | CPC
They are just about full range . They do need something almost like a crossover to get the best from them . I will also be careful about bass filtering . Treble filtering also . Then we can equalize the response a little . I will be using an extra bass unit and tweeter . However 90% of the speaker will be this unit . It is very likely I could use just this speaker on it's own ( in a box or on a baffle ) and be very happy . I dare say if very carefully tilted both backwards and inwards almost no correction would be required . The bass filtering might improve mid range qualities whilst removing little or no bass .
Looking at the graphs I think a beginner will understand plenty . This PDF is almost a complete teaching coarse !
http://www.eminence.com/pdf/Beta_12LTA_cab.pdf
Old 29th July 2013, 10:52 PM   #10
frugal-phile(tm)
planet10's Avatar
Ladies & Gentlemen - The Emken
Beta 12LTA in a 3cf box - port size
dave
Full range speakers the way to go? dave123456@mail Full Range 18 24th September 2013 11:52 PM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 04:07 PM
what are full range speakers? legendaryfrog Full Range 10 10th November 2006 02:35 AM
Multimedia Satellites, Open Baffle?, Full Range? Driver Selection Help Required ozynigma Multi-Way 32 7th May 2004 04:29 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
