Could i build a backload horn whith Axiom10
Old 25th July 2013, 03:15 AM   #1
santitrucco is offline santitrucco  Argentina
Default Could i build a backload horn whith Axiom10
I have a pair of Goodmans Axiom 10 Speakers..
I would like to build a backloaded horn for this speakers..
Is a good option ?
i do not know thiell small parameters
Somebody could be help me ?
thanks friends
santiago
Old 25th July 2013, 06:59 AM   #2
GM is offline GM  United States
GM's Avatar
Based on the factory recommended reflex cab, it can be BLH loaded, but with no specs..........
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th July 2013, 09:41 PM   #3
I have a pair New never used , and some friends believe that can do the best in Back loaded horn , i am building a horn loaded , but i do not know the results
thanks a lot GM
Old 25th July 2013, 10:11 PM   #4
xrk971 is offline xrk971  United States
xrk971's Avatar
Do you have means of measuring TS params? I hear it can be done with pc sound card and 10 ohm resistor and wiring.
Old 26th July 2013, 01:23 AM   #5
i have Praxis from Liberty Instruments , but in this moment a friend of my is utilizing the Praxis
Old 26th July 2013, 03:02 AM   #6
xrk971's Avatar
http://m307.photobucket.com/albumvie...ce/09.jpg.html
Old 26th July 2013, 03:06 AM   #7
good , thanks
Old 26th July 2013, 06:09 AM   #8
GM's Avatar
Then you can measure T/S specs.
GM
Old 1st August 2013, 03:34 AM   #9
zelgall is offline zelgall  Canada
I have a pair of twinaxiom 10's that I can measure tomorrow. They're basically the same but different vintage and they have a small whizzer. It should be close. I wouldn't think that it would change much on the box side. The whizzer is about 3/4" long (or deep) and of relatively small diameter.
Old 1st August 2013, 05:12 PM   #10
Here's two Goodmans twinaxiom 10's
unit 1
Buffer[1] Vas Ver 7.01
Completed: Thu Apr 25 17:57:27 2013
Drive level 100.000% [3.615 mA]
Sine,LoZP(LV/LA)->Vas,21 pts
Re = 13.7772 ohms
Fs = 51.7573 Hz
Zmax = 54.5619 ohms
Qes = 1.9372
Qms = 5.7348
Qts = 1.4481
Le = 0.5175 mH (at 1 kHz)
Diam = 222.2500 mm ( 8.7500 in )
Sd = 38794.7895 mm^2( 60.1320 in^2)
Vas = 126.3630 L ( 4.4625 ft^3)
BL = 6.0829 N/A
Mms = 15.9989 g
Cms = 591.0287 uM/N
Kms = 1691.9651 N/M
Rms = 0.9072 R mechanical
Efficiency = 0.8498 %
Sensitivity= 91.3111 dB @1W/1m
Sensitivity= 88.9504 dB @2.83Vrms/1m
Krm = 52.299E-06 ohms Freq dependent resistance
Erm = 1.075E+00 Rem=Krm*(2*pi*f)^Erm
Kxm = 6.182E-03 Henries Freq dependent reactance
Exm = 721.330E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 34.035 Hz
Ftest/Fms = 0.6576
Test Mass used = 21.0000 g (Equal to 4.2 nickels)
Test Mass (Ft=Fms*0.90) = 3.753 g (Add -17.247g for Ft=46.582)
Test Mass (Ft=Fms*0.75) = 12.444 g (Add -8.556g for Ft=38.818)
unit 2
Completed: Thu Apr 25 18:23:33 2013
Drive level 100.000% [3.616 mA]
Sine,LoZP(LV/LA)->Vas,22 pts
Re = 13.9780 ohms
Fs = 55.2288 Hz
Zmax = 55.8164 ohms
Qes = 1.9612
Qms = 5.8701
Qts = 1.4700
Le = 0.5414 mH (at 1 kHz)
Vas = 124.2467 L ( 4.3877 ft^3)
BL = 5.9450 N/A
Mms = 14.2901 g
Cms = 581.1303 uM/N
Kms = 1720.7844 N/M
Rms = 0.8448 R mechanical
Efficiency = 1.0028 %
Sensitivity= 92.0302 dB @1W/1m
Sensitivity= 89.6066 dB @2.83Vrms/1m
Krm = 15.213E-06 ohms Freq dependent resistance
Erm = 1.183E+00 Rem=Krm*(2*pi*f)^Erm
Kxm = 6.772E-03 Henries Freq dependent reactance
Exm = 715.802E-03 Xem=Kxm*(2*pi*f)^Exm
Ftest = 35.144 Hz
Ftest/Fms = 0.6363
Test Mass (Ft=Fms*0.90) = 3.352 g (Add -17.648g for Ft=49.706)
Test Mass (Ft=Fms*0.75) = 11.115 g (Add -9.885g for Ft=41.422)
Could i build a backload horn whith Axiom10Hide this!Advertise here!
Horn build recommendations? batsong Full Range 16 9th April 2013 06:42 AM
Horn Build using a tapped horn as a frame?? 3GGG Multi-Way 1 18th January 2012 12:52 AM
RH84 bias change whith different el84 is use tim614 Tubes / Valves 1 26th June 2009 11:23 PM
help whith a low voltage dc/dc converter schematic adi109cj Power Supplies 2 6th February 2008 01:12 PM
Moved+changed preamp and now got hum and dc-offset whith chipampkits MiWi Chip Amps 1 4th August 2006 05:40 PM
Copyright ©1999-2017 diyAudio
