Subwoofer for Fostex Fe103 - diyAudio
Old 23rd July 2013, 06:25 PM   #1
Default Subwoofer for Fostex Fe103
please can you address me to a project of a subwoofer with plate amp for my PC system to help under the desk two monitors with Fostex FE103 drivers in the Fostex standard BR enclosure?
Thank you
Northernsky
Old 24th July 2013, 01:33 PM   #2
My system is similar (FE103E in BR tuned to ~80Hz). My only recommendation is to make sure that the plate amp has an adjustable low-pass filter, so you can blend the sub in (by adjusting its uppermost frequency).
For example, in my case, I have a floor-to-ceiling resonance (room mode) at about 70Hz. So the FE103's play down to 80Hz, then the sub is limited at ~60Hz, to avoid aggravating the 70Hz "boom".
Old 24th July 2013, 02:45 PM   #3
Thank you Rybond3rd,
What sub do you use?
northernsky
Old 24th July 2013, 02:59 PM   #4
xrk971 is offline xrk971  United States
xrk971's Avatar
You might want to check out what James Shearer did for a sub for use with his Met's. It is the "Triska" design. Another Triska Sub
Parts Express DIY Project
Old 24th July 2013, 03:25 PM   #5
picowallspeaker's Avatar
Uh! I did something like the Triska sub, having two Peerless woofers (subs )
one of them had the voice coil former detached from the cone ( abuse !)
so I detached also the magnet and transformed it into a passive.
I added some weight too.
The wood, i got it from a couch on the street.
The two radiators are placed on the near walls of the box, but the passive ( or the active ) might be placed on the opposite face.
I don't understand why the electonics have to fit inside the box !?!
Mine is powered by a BTL 2 W amplifier so...4 W or something. The electronic filter ( based on a TL 074 ) as the amplifier belongs from a Philips 2.1 system.
It now plays ( I didn't tell them the trick ! ) with a pair of Whaferdale Diamond 9.1 powered by 20 + 20 W .
Old 24th July 2013, 03:54 PM   #6
I use a very cheap Hsu 10" sub. It has the low-pass -- I had intended to get the model which -also- has a high-pass. But I guess I didn't read the fine print.
So now, I go direct to a Bottlehead amp (no high pass), and then I use the low-pass to blend in the sub. But it's convenient if you get a plate amp which -also- has the high pass (as an option, at least for experimenting).
Old 25th July 2013, 01:00 AM   #7
Jim Shearer's Avatar
If you do the Triska sub project, I would strongly recommend a better plate amp; the little plate amp that is in the BOM for the Triska didn't work very well for me.
Cheers, Jim
A day without music is like a day without food.
Old 25th July 2013, 08:25 AM   #8
cradeldorf's Avatar
My system is running a Dayton 12" ($120) from Parts express. Not sure if it can hook to a computer or not though...never tried. It's a great sub if you want to bring the ceiling down. It's paired with a set of Homebrew OB's with Fostex 103En's a pair of full range 5"ers I got out of my old Magnavox 50" bigscreen and a pair of Eminence Alpha 15's for the thump. Just got the crossover figured out today.
Old 25th July 2013, 03:17 PM   #9
Thank you for all the suggestions. The Triska sub is the kind of project I was looking for; I am not a big expert: I can just copy.
Concerning the plat amp I have to look for something different; here in Europe it should be easier to find a Monacor plate (more expensive anyway).
Northernsky
Old 25th July 2013, 08:46 PM   #10
Godzilla's Avatar
I agree the amp used in the triska is not the best (I own it). I'd recommend 100+ watts for a sub amp.
Fostex recommended FE103 Enclosure Rega Full Range 27 12th January 2008 07:59 AM
Anone have experience with this fostex FE103 design? gnugear Full Range 11 5th October 2007 07:41 AM
Damping For Fe103 Fostex Recommended Horn stevenc Full Range 1 8th August 2007 12:21 PM
best enclosure for fostex fe103 jesserparker Multi-Way 10 3rd August 2005 05:05 AM
Fostex Fe103 combined with woofer. jim Multi-Way 25 21st August 2004 07:53 AM
Copyright 1999-2017 diyAudio
