Karlsonator
Karlsonator
Old 25th September 2013, 05:06 AM   #161
Greg B is offline Greg B  United States
Originally Posted by tomlang View Post
A question on the enclosure, however, it appears to show two builds, one with dotted red lines? Can anyone (Greg B?) elaborate?
I think you've gotten the answers to that already, but just to elaborate:
The dotted line in the center divider shows a simplified/easier construction option for the center divider. Since you are CNC equipped, go for the solid line... Smoother expansion and the center divider will be stiffer.
Though it may be worth playing around with, I'd recommend the 'standard' 39" radius K-aperture. The dotted lines show an experimenters' option. It think it would be too laid back with the FE167.
I'm looking forward to seeing this build!
BTW, years ago, Gregg Baker (eeehaah) had a prototype CNC'ed Karlson made. He was hoping to offer it as a flat pak kit, but there wasn't any demand at the time.
Old 25th September 2013, 11:53 AM   #162
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Karlsonator
I'm going to use the Home Depot aracao plywood that is .73 inches thick. I took into account the extra thickness in the hard to read drawing shown.
I started to program the CNC. All panels will be rabbeted, mitered, and cut by the machine using a 1/4" straight bit as shown in the rendering of a few of the panels.
I'm not sure I will brace this since I am using 3/4" thick material.
Must be nice to have your own CNC
Looking forward to this build and your listening impressions.
Old 25th September 2013, 09:09 PM   #163
fishinjc is offline fishinjc  United States
Originally Posted by xrk971 View Post
Has anyone ever tried the Karlsonator with an Eminence Beta 10CX PA driver? This is a really nice powerful driver that seems attractively priced. It will need the coaxial CD for the built in horn, or add a K-tube CD externally. I ran a simulation and adjusted the top channel by increasing it by 1.3X to get more bass amplitude to balance it out a bit. The f3 is 39 Hz (95.6 dB at 1 watt 1 meter), not too bad. If I were to build a full scale K'nator, I think I might go with this driver for a bang for the buck consideration.
First plot is freq response at 1 m, second is impedance, third is cone displacement (well controlled), fourth is impulse response (very clean).
The flat bass shelf on this combo can't be beat (IMO).
I'd like to try this with the coaxial CD, but I'm not sure how to go about increasing the top channel by 1.3x. Raise the roof or lower the inside bit?
Old 25th September 2013, 09:43 PM   #164
freddi is offline freddi  United States
freddi's Avatar
Karlsonator
would a Karlsonator "10" built between the 12 and 8 sizes play well with Beta10cx? (Beta10cx is a lot of fun in K12) I need to find someone to cut a Karlsonator 12 - I've too much pain from costochondritis to monkey with stuff.
Old 25th September 2013, 10:06 PM   #165
Got Foam?
xrk971's Avatar
Karlsonator
If you lower the inside a bit, that is least disruptive to everything else and should work well. Are you going to try the Beta 10CX?
Old 25th September 2013, 10:15 PM   #166
tomlang is offline tomlang  United States
tomlang's Avatar
I'll certainly consider cutting some of these for the folks here. Let me take a step back and 3D model the K-6 in Sketchup to be sure I don't miss anything. I've done this before with other items I have built and then I know all fits once I get done machining the parts.
Once the K-6 is done, I can do the K-8 and K-12 also. Mods to these (especially width) would be easy...
So in the next few days when I get a chance I'll do a 3D sketchup with exploded parts of the K-6... and post it here.
Old 25th September 2013, 10:23 PM   #167
Got Foam?
xrk971's Avatar
Karlsonator
A Beta 10CX should be used in a full size Karlsonator (15 in). It will work in a 10/15 scaled one but at the expense of bass extension. Although you gain some efficiency. These sims are with a wall far away so you are not getting the added bass extension from a back wall.
Full Size
10/12 Scale
File Type: png Karlsonator-Full-Size-Beta10CX-Freq-1m.png (17.3 KB, 515 views)
File Type: png Karlsonator-10o15X-Beta10CX-Freq-1m.png (29.0 KB, 515 views)
Old 25th September 2013, 11:22 PM   #168
freddi's Avatar
Karlsonator
F10 `50Hz for the 10/12 Karlsonator seems an acceptable tradeoff - how about Beta 10CX versus Kappa 12A in GB's Karlsonator 12? - a pair of Karlsonator 8s should be nice too - dunno if the stock Karlsonator8 would match a Tangband 1772 - ? (also have Beta8cx and Nirvana stamped frame Super 8s) FE206EN had the most punch/attack for an 8" FR in a regular Karlson K12. Beta 10cx is a good high-value driver.
Old 26th September 2013, 01:11 AM   #169
Yes. Beta 10CX w/ Selenium DT220Ti and the 2k5 crossover. Is the "full sized version" the "Karlsonator" from post #1?
Old 26th September 2013, 03:54 AM   #170
Got Foam?
xrk971's Avatar
Karlsonator
Yes, go full size. The vent scaling by 1.3x is optional as it looks pretty good with 1x vent as seen above.
KarlsonatorHide this!Advertise here!
Mini Karlsonator (0.53X) with Dual TC9FD's xrk971 Full Range 2826 16th June 2018 09:55 PM
