Mini Karlsonator (0.53X) with Dual TC9FD's
Old 5th April 2014, 01:23 PM   #561
Carlp is offline Carlp  United States
Originally Posted by xrk971 View Post
Blaides,
That sounds like a good idea. If FC panels were long enough you could make the entire speaker out of one long strip! Glue second panel for the double layer portion.
Oooh. I hear a challenge... What about your tiny box?
Old 5th April 2014, 08:18 PM   #562
BL21DE3 is offline BL21DE3  Scotland
BL21DE3's Avatar
Blaides,
Thanks for the idea. As my sheet is 841mm long I can easily do this.
Challenge accepted
Sheets have been cut and are awaiting assembly .
Old 7th April 2014, 03:05 AM   #563
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Ok Blaides,
Did you glue her together yet???
Old 7th April 2014, 07:33 AM   #564
BL21DE3's Avatar
Hi X,
I haven't got round to gluing yet, other 'DIY' got in the way. But everything is pretty much ready to assemble, I just need to fold the baffle to shape. I was experimenting on scrap foamboard to get the depth etc. right before committing to the real baffle. Hopefully I'll get a chance tonight to get gluing.
With regards to bracing in the 0.4x version, I take it an approach like the one you used in your 0.53x build would be advisable?
Old 14th April 2014, 11:26 PM   #565
Got Foam?
xrk971's Avatar
This is a nice amp for mini Karlsonator:
TDA7297 and Karlsonator
Old 15th April 2014, 02:52 AM   #566
AZDoug is offline AZDoug  United States
XRK, if I were to make a karlson speaker with 4 vifa drivers, how large should it be.
Also would it be better if the 4 drivers were in a square 2X2 pattern, or a tilted
2x2 diamond pattern. Been too busy lately with life to mess with DIY speakers for awhile. I might have time later this week, to build some.
Old 15th April 2014, 03:39 AM   #567
Got Foam?
xrk971's Avatar
AZDoug,
If you want to do the 2x2 driver in a mini Karlsonator, it won't get your any higher efficiency in series/parallel wiring. However, you will lower the distortion significantly as the cones move less. I would do a diamond config in a 0.75x scale in height and depth and 0.53x scale in width. You may want to use a 4 ohm + 1 mH + 1 uF BSC circuit (all in parallel) as the four drivers now will have more mids/highs compared to bass of two drivers.
Good luck,
X
Old 15th April 2014, 04:30 AM   #568
Got Foam?
xrk971's Avatar
AZDoug,
You may have to scale the width by 0.75x as well to have enough room for the diamond array of drivers. It will make a peakier bass at low end but can be adjusted with stuffing.
Old 16th April 2014, 09:24 AM   #569
Morfeus is offline Morfeus  Germany
I have two Peerless HDS PPB 4-25 8Ohm and two Fostex FT 17 H Horn Tweeters - 8 Ohm.
Would those work in the Mini Karlsonator? I am looking for small size and as much bass extension as possible. I could add a H-frame sub with Eminence Alpha 15 though.
Old 16th April 2014, 03:49 PM   #570
DeonC is offline DeonC  South Africa
DeonC's Avatar
Default Mega-Karlsonator?
Hi guys
I am sorry to come into this thread sideways, but I would first like to hear if my idea is viable at all before I start a whole thread on it.
I want to build a pair of high quality subs for home use. The drivers I am going to use for this sub are the 13" Leak Sandwich bass drivers. I already have 1 pair of ceramic bass drivers and 1 pair of alnico drivers. I am going to get another pair of each for the sub idea I have in mind. Each box will have two ceramic and two alnico drivers in. I will be quad-amping each sub. One of the main box design ideas for I have in mind is a mega-Karlsonator, and I want to know if it will work.
The boxes that I am planning to build will be 188cm (1.88m/74"/6.16ft) tall x 57cm (22.44") wide x 55cm (21.65") deep. The internal measurements will be 182cm (71.65") x 51cm (21.08") x 49cm (19.29"). With that height it will be a real mega-Karlson to start with, but I want to make it a Karlsonator (Karlson crossed with TQWP) design. I estimate with the height of the box that this design should go down low, very close to 20Hz at the bottom end. The problem is that I don't have any TSPs for any of the drivers, but I will also be buying the Dayton measuring suite, and I will be measuring each individual driver. But before I even start that, I want to know if such an idea will work at all. If the Karlson experts give the green light for this idea, I will create a new thread on the Subwoofer forum. Here is a pic for my idea:
Thanks,
Deon
I don't suffer from insanity. I enjoy every minute of it.
Have a look at my favorite thread: Interesting YouTube video clips
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 03:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 12:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
