Mini Karlsonator (0.53X) with Dual TC9FDs
Hi Guys. I've been laying low for a while now but ready to start experimenting again. I got these four mid/woofs and two tweekers plus their crossovers the other day and looking to put them in something. The mid/woofs are 3" and the tweets are 1". I was thinking about a scaled down Karlson but don't know how to size it. I assumed the tweet would go right above the slot. Any thoughts?
DJN,
Nice find! Those look like powerful motors, probably Qts in 0.4 range. Can you measure the T/S params? I will design a mini Karlsonator for you based on the measured T/S. Did you ever build that 0.4x desktop mini K'nator?
No X, right around that time, personal matters popped up that are just now settled. I haven't sat and listened to my big system since then either. THis project will mark my return!!! These drivers and xovers are from a Visio Sound Bar. I was supprised at the quality actually. I'll get them measured up Sunday and post the results. Do I need to find the Vas as well???
Yes, the Vas is needed - use the added weight (modeling clay or coins of known weight) trick.
So that is what is inside a $100 Vizio sound bar? Those things sound good, I am amazed when listening to them at Costco. What is even cooler is they have a built in amp and SPDIF input. Sometimes I wonder why we don't use these as MP3 player "Boomsticks"?
Hi X, got the little buggers all measure up. Here is the WT3 screenshot. Impressive little guys but I hope they will be right for the Karlson. I have a pair of Paradigm MK 3s for my computer system. These Ks will replace those, so that is my target sound to beat.
Vizio dual 3in driver mini Karlsonator
I think that using these as dual drivers (series for 8 ohms) can work well. Just add the stock tweeter at the top above the narrow slot area. Use the supplied XO and you should be golden. There is quite a bit of bass gain so BSC should not be an issue. The sim assumes they are 12 in away from a back wall and sitting on floor. The scaled size is 0.47x tall & deep, 0.35x wide. Make the K-aperture come to a slot as usual (not a cusp). I hope you will build them, they look like they should sound good.
Freq Response (flat to 60 Hz), note ripples from 300Hz on up are floor/wall bounce cancellation effects:
attachment.php
Cone Displacement:
attachment.php
Impedance:
attachment.php
That all looks great X. Sorry for my ignorance, but .47x of what? I looked through this whole thread because I remember reading and seeing the stock dimensions that the scaling is based on, but I can't find it.
We have a SMAC (southeast michigan audio club) meeting at the end of the month and I'd like to get them done by then so they can be auditioned by the group.
