Mini Karlsonator (0.53X) with Dual TC9FD's
Old 1st February 2018, 03:38 AM   #2471
perceval is offline perceval  Taiwan
perceval's Avatar
I forgot to add that I ran out of audio connectors.
Since this is DIY, I looked around what I had at the house, and found my box of Wego connectors. They work very well as quick-connects. And talk about cheap!
Old 1st February 2018, 08:03 AM   #2472
perceval's Avatar
Yet having more fun with the mini-k back home.
Using a pair of subs, crossed at about 80Hz like previously mentioned.
The mid range is excellent. Bass is supported, so that's fine too. It's a setup one could listen all day and not feel fatigue.
Old 3rd February 2018, 03:36 PM   #2473
davetest is offline davetest
Nice looking setup. I could maybe do with building a sub like that. Can you give any details please?
Old 4th February 2018, 01:53 AM   #2474
perceval's Avatar
Easy enough.
I used XPS foam for quick test builds, but they would really need wood or mdf to sound best.
The driver is the w8-1363sbf, with a low Vas and high X-max. They are in a sealed box. It was vented initially, but group delays were noticeable, so plugged it, and now it's much better. I'm only losing about 3Hz by going sealed in this case, so, the move was a good one.
I'm using a salvaged plate amp from Acoustic Research to drive them. Most of those amps have a boost bump at about 30Hz, variable gain, variable XO and phase. Easy to blend with most speakers, and certainly easy with the mini-k. I cross at about 80Haz in this case.
My pre has a sub out, so, full range goes to the mini-ks and sub out to the sub amp.
Very simple, but effective!
Old 5th February 2018, 06:49 AM   #2475
yianemma is offline yianemma
Originally Posted by xrk971 View Post
Check out this new 0.53x dual 3FE25 from Skylar88. Should be good for 97dB at 2.83v!
http://www.diyaudio.com/forums/attac...onator-053-pdf
Hello to everyone. Would it be ok to build this box and throw in 2 visaton frs8-8 that I have in hand, just to test the dual setup on mini karlsonator? Just to cross check, are the dimensions in mm and the thickness of material (maybe ply is used here) at 12mm?
I am here after xrk's suggestion on speaker selection for my living room. I have to test them before I order 4 3fe25 drivers. I know that the sound may not be optimal using the visatons, but I guess that I'll be able to see if I like them (I've showed a picture of them to my wife, she prefers the tabaqs, but that shouldn't be a problem)
Old 5th February 2018, 01:25 PM   #2476
jwicaksana is offline jwicaksana  Indonesia
Hi perceval, would you link me to more info about your sub? Thanks!
Jonathan
Old 8th February 2018, 03:32 PM   #2477
Mazeppa is offline Mazeppa  United States
Default 0.40x/TC9FD18-08
Just put together a pair Mini Karlsonators.
As advertised, the build was quick, easy, and also stress free; I mean we're talking about what, $30 worth of material here?
Hey, if I don't like them I'm not even out much time.
Hooked them up to WAV files from a 15 yr old laptop, through a stock Topping D-20 DAC to a home brew 12W RMS into 8ohm chip amp.
Gotta tell you, these things don't have any right to sound so good.
Strength is the mid/lower treble range which is consistent for what one should be able to expect of this driver.
Treble/bass regions are present enough in good quality to support the strength of the drivers. Well done Xrk971, and thank you for not trying to do too much in these outer areas and winding up with some flabby bass and harsh highs that would detract from what the drivers do the best.
Another surprise was the excellent sound stage. Lead vocals are centered, instruments and backing vocals biased to one side or the other.
Really cool.
I used MuddJesters 0.40 plans. Couldn't get the back/side section to fit quite right and wound up with 50% of the port area at the top.
1/8" thick felt behind the front baffle, 1/2" thick open cell foam in the indicated areas. Fill was fiberglass insulation batts.
Forgot the brace inside the inner chamber, so I left it out of the 2nd one.
Design is forgiving, indeed.
Anyone out there on the fence about trying this project, quit wondering and get busy.
Old 8th February 2018, 07:33 PM   #2478
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
My 1 watt tube amp drives these things like a champ off of an old beater laptop! It's insane that I'm hearing such bass and imaging out of some craft supplies and two speakers!
I've fallen in love with these things for sure. It's unreal how nicely they work! I like them so much I want to do a pair of the bigger ones, and build up a nice DAC to use with them.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 8th February 2018, 08:41 PM   #2479
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Mazeppa and Lingwendil,
Great news! So glad you like the sound. It is a forgiving design - thanks to GregB for original full scale Karlsonator. I just made it smaller and out of foam core. It’s a very accessible DIY project with huge rewards.
Thanks for sharing,
X
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 13th February 2018, 02:46 PM   #2480
hehejaa is offline hehejaa  Spain
I've tried to look through the thread for a drawing of the .53 in centimeters, I can find a lot of good drawings for the .40 but not for the .53 , have I missed something?
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 03:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 12:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
