Mini Karlsonator (0.53X) with Dual TC9FD's
Old 14th January 2018, 07:52 PM   #2391
Skylar88 is offline Skylar88  South Africa
Originally Posted by Lingwendil View Post
That's a fantastic looking amplifier!
Any details on how you did the heatsink/enclosure setup?
The enclosure construction is really very simple. So far I've just bolted aluminum plates to the underside and rear with 3mm bolts which fit into holes drilled and tapped into the heatsinks. I'll add a 6mm aluminum faceplate to the front and the top will get a 1.2mm alu plate that will be recessed to fit flush with the top of the heatsinks. That's about it. I may send the heatsinks in to be anodized and all the aluminum plates except the front will then also get a coat of paint.
First DIY audio projects: B1 + ACA + dual FaitalPro 0.53x Karlsonators = awesome sound
Old 14th January 2018, 08:37 PM   #2392
freddi is offline freddi  United States
freddi's Avatar
what a beautiful heatsink/enclosure - your upcoming aluminum face-plate and top will look fabulous. What is used for the cap multiplier voltage reference? - (I've always liked cap multipliers in tube preamp PS better than feedback regulator)
Old 14th January 2018, 09:55 PM   #2393
xrk971 is offline xrk971  United States
xrk971's Avatar
That’s the Juma cap Mx circuit. Simple IRFP240, 10k, 220R, 1.5R, 220uF cap to be Mx, 1uF film snubber cap, 1N4004, 4700uF output.
Juma's Easy-Peasy Capacitance Multiplier
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 15th January 2018, 03:10 AM   #2394
perceval is offline perceval  Taiwan
perceval's Avatar
I have some thin plywood of 3 and 5 mm thick.
I think I will try that for a 0.53x mini-K. I got the 4 TC9s in storage, so, might as well put them to good use!
PS. The 0.53x diagram in the first post is still up-to-date? Just checking, as I got burned on my 0.4x build, following the wrong dimensions...
Old 15th January 2018, 06:27 AM   #2395
Originally Posted by xrk971 View Post
Thatís the Juma cap Mx circuit. Simple IRFP240, 10k, 220R, 1.5R, 220uF cap to be Mx, 1uF film snubber cap, 1N4004, 4700uF output.
Yes, it's Juma's Cap Mx and this is a diagram for two-channels that I adapted from the one in that thread. I used IRFP250 because it was cheaper and more readily available.
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 04:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 01:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 11:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 05:06 PM
