Mini Karlsonator (0.53X) with Dual TC9FD's
Old 23rd December 2017, 08:15 PM   #2341
enquirez is offline enquirez
Hello, gentlemen!
Started to think of new project after moving from Omsk to Moscow. Its here in Russia, if you're need to know) So I looked through few threads and saw p830986 is the only model of drivers I should get, they being affordable and available from ali. Maybe some visatons are an option, but I don't know if they're any better.
So if I use two of that chibese peerless in one speaker which scale should I go with? 0,53 or 0,4 or...
Old 23rd December 2017, 11:09 PM   #2342
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Two would be 0.53x and one is 0.40x. 830986 is a fine driver - should work well with deep bass and nice highs.
XRKaudio https://www.etsy.com/shop/XRKAudio
Old 23rd December 2017, 11:12 PM   #2343
Got Foam?
xrk971's Avatar
Originally Posted by davetest View Post
@xrk971. The 0.4s that GraphicCanuk built are 6.5". Do you have any info on expected performance vs 6" wide?
Iím not sure why he went 6.5in? But that increase volume to give deeper bass but needs to be simíd. If too big will make mid bass sag. Although 0.5in wider is no big deal. Itís a very flexible tolerant design.
Old 24th December 2017, 06:51 PM   #2344
cakeman is offline cakeman  Finland
I've been listening to my 0.53x's (Dayton Audio PA-130-8 version) for couple weeks now once again. They still sound very good! At this price point you obviously have to have some limitations on what you expect your speakers to deliver. Most of the time these little speakers don't care what you throw at them, they deliver just good sound all day long. The volume levels that these little speakers are capable of is just stunning.
Just like some other small full-ranger drivers in different applications these just love to play stuff like man with hes guitar. Mid-range is an obvious strong point for these speakers. Really good bang for the buck these little speakers and I would highly recommend these for everyone to build. I could see these speakers playing music in a garage, office, bedroom etc. Just a really good reference point what you can achieve with mere 100 bucks for a pair of speakers.
Here is a good example from youtube, what I like to listen to with these speakers.
YouTube
Old 24th December 2017, 10:26 PM   #2345
Got Foam?
xrk971's Avatar
Thanks for the nice report Cakeman! Indeed the PA130-8 Karlsonator is an awesome value for the sound quality. With $5 of foam core, $38 in drivers it’s under $50 for me. Is yours made of wood or foam core? I have a theory that the foam core ones sound better.
Old 26th December 2017, 08:16 AM   #2346
Originally Posted by xrk971 View Post
Thanks for the nice report Cakeman! Indeed the PA130-8 Karlsonator is an awesome value for the sound quality. With $5 of foam core, $38 in drivers itís under $50 for me. Is yours made of wood or foam core? I have a theory that the foam core ones sound better.
12mm birch plywood.
Old 1st January 2018, 05:19 PM   #2347
MikeV is offline MikeV  United States
Hi Skylar88!
you've got me intrigued with your build using dual Faital 3FE25. Easy build with the foam board construction, and Higher efficiency. Win-Win!!!
Got any pictures?
Happy New Year all!!
Old 1st January 2018, 07:48 PM   #2348
Skylar88 is offline Skylar88  South Africa
Originally Posted by MikeV View Post
Hi Skylar88!
Got any pictures?
Hi MikeV
There are some pictures in my ACA Speaker short list thread. Also check out the update in post #103 where I added baffle steps to tame the high frequencies.
And after completing my Amp Camp Amp, they sound even better.
Old 2nd January 2018, 04:49 PM   #2349
Hi Skylar88!
Thanks for pointing me there! Don't know how I missed it, but I did! (doh!)
Very nice work! Very inspiring! I'll do my best to emulate your results!
Thanks!
Old 9th January 2018, 12:46 PM   #2350
Default Disappearing speakers
As some of you know, I have recently built a pair of 0.53x Karlsonators with dual 3FE25-16 FaitalPro drivers. The sound was very good when powered by my B1 buffer preamp + TDA7297 chip amp. Iíve enjoyed the speakers a lot until I completed and connected my Amp Camp Amps.
This is probably important info, so Iíll mention it here. I followed the advice of Paul McGowan of PS Audio to position the speakers away from the front wall so that an equilateral triangle is formed between me and the speakers. See picture below.
While the sound is even better than before (sometimes downright amazing), I canít hear the speakers for the most part. On the majority of music tracks the sound is in-between the two speakers and slightly behind while there is hardly any sound coming from the speakers themselves.
Have I wasted my money and time building these speakers, because now I canít even hear them?
PS Maybe I should have kept this post until April.
Mini Karlsonator (0.53X) with Dual TC9FD'sHide this!Advertise here!
Dual HL10c / dual CSS APR12 / Hypex PSC 2.400 airguitarchamp Subwoofers 0 1st April 2013 03:50 PM
Any ideas for the VIFA TC9FD-18-08 WrineX Full Range 19 5th March 2012 12:57 PM
Mac Mini dual DAC crossover OzMikeH Digital Line Level 2 12th January 2009 10:11 PM
Dual hi-vi mini project BionicSniper Multi-Way 23 7th August 2008 04:06 PM
