Pensils for Alpair 10.3 & Alpair 10p - Page 7 - diyAudio
Old 14th September 2013, 03:16 PM   #61
Bigun is offline Bigun  Canada
Bigun's Avatar
The Dayton plates have been selected.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 14th September 2013, 08:02 PM   #62
mp9 is offline mp9  United States
Good choice.
I especially like the look of the black anodized aluminum but can see they won't couple well with my CablePods.
I ordered .250 1/4" 4"x4" Aluminum sheet plate from ebay. I will drill them to spec -
250 1 4" Mill Finish Aluminum Sheet Plate 6061 4" x 4" | eBay
Old 14th September 2013, 11:46 PM   #63
Bigun's Avatar
Yes, the black plates 091-602 I believe and the BPP-Premium gold binding posts to suit.
I've doubled up on the front baffle just behind the driver only, as that's what I had in the scrap pile. But seem to have lost the relevant router bit so I'll have to wait for a trip to the store now. In the meantime I'm starting to glue up the side panels to the rear panel. The front panel will be glued in after routing. Then I'll do some simple braces from the scrap bits and finally the top and bottom can go on ( I modified the design to allow the top and bottom to go on last).
The drivers are slowly cooking at my friends house, he says they don't sound promising, somewhat metallic. Well, pretty much what I'd expect for a raw driver fresh from it's birth. It'll loosen up and the sound will fill out nicely in the box - judging by what others have to say.
Old 14th September 2013, 11:55 PM   #64
vinylkid58's Avatar
Didn't you say he liked paper coned drivers, or was that someone else?
jeff
Old 19th September 2013, 08:45 PM   #65
Bigun's Avatar
Yes I did say that, but he ended up selecting the metal cones based on the good reports he has read about them. They are cooking nicely, already showing quite a bit of improvement.
Old 31st January 2014, 04:57 AM   #66
McDark is offline McDark  Russian Federation
Send a message via ICQ to McDark
Just got hands on 10M3 and 10P, gonna try them both with different class D and compare.
And er... just noticed, what exactly this 812mm(31 31/32) dimension should be linked to? In 7.3 design alike dimension gives driver center height off floor. Seems to me it should be corrected or maybe just removed as front panel height can be achieved anyway from back panel height and port size.
Yuri
Old 31st January 2014, 05:52 AM   #67
frugal-phile(tm)
planet10's Avatar
Originally Posted by McDark View Post
... what exactly this 812mm(31 31/32) dimension should be linked to...
Thanx, fixed.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 30th October 2014, 10:34 AM   #68
Hello Everyone
My Alpair 10.3 s arrived here in Bangalore after changing three hands from US due to the schedule changes at my friend's end who was to originally carry them for me.
Now as I am about to place the order for wood(Birch Ply-19mm) What cabin design I should opt for ?
1.Mostly I listen to 70's to 90's rock with very occasional Jazz(When I want to sound snobbish!
2.WAF and real estate the Horns are out-essentially between pencil 10.3 s BR book shelves What and why Should I choose a particular design
3.This will be installed in my Bedroom with a NAD 320BEE and a PC with all the music in .WAV form and Maudio DAC
4.I may go in for a Tube amp later...and I like reasonable low end and the upper end should be smooth yet present noticeably.
Thanks a lot folks...
Old 30th October 2014, 03:53 PM   #69
chrisb is offline chrisb  Canada
Based on experience with a wide of drivers by Mark and others, I've found that a floorstanding MLTL delivers more bass extension, dynamics and articulation than any "bookshelf" sealed or vented enclosure for the same driver.
If there's any way that limited floor space could still accommodate the footprint of Pensil, I doubt you'd reget the choice.
on hiatus
Old 30th October 2014, 05:02 PM   #70
Thanks a lot Chrisb.Pencil it is .....
Frugel-Horn XL for Alpair 10.3/10p planet10 Full Range 767 18th April 2017 06:49 PM
Jordan Eikona 2 vs MarkAudio Alpair 10.3/ 10p rockk19 Full Range 111 15th March 2017 10:11 PM
FS: Alpair 10P + Pensils JP Swap Meet 6 5th January 2015 04:17 AM
Alpair 7.3 10.3 and 10p vs EAD in WinISD smallangryboy Full Range 6 2nd November 2013 07:25 PM
Copyright 1999-2017 diyAudio
