building one's own diaphragm
Old 20th August 2013, 08:34 PM   #11
el`Ol is offline el`Ol  Germany
Mic distance is < 1 m.
I didn't like the massive smoothing of gated measurements (no idea whether this problem can be fixed, I'm no ARTA expert), so I posted ungated measurements.
Meanwhile I also amputated what was originally considered the tweeter diaphragm, leaving only what was originally considered the connecting element. The arrangement has no similarity with anything that is currently considered a sound transducer, but I like it best that way.
And yes, these are 15 steps.
Old 21st August 2013, 07:24 AM   #12
markus76 is offline markus76  Germany
Banned
Thanks. The graphs for 30, 45 and 60 are exactly the same?
You would need to look at free field measurements to separate driver/enclosure effects from room effects. Gated measurements will help with that. Yes, it does reduce frequency resolution but so does 1/12 octave smoothing you used in the graphs above.
Old 22nd August 2013, 05:47 PM   #13
Yes, 30/45/60 look the same, hard to believe. A file saving problem of Darkshot? Or the time limit for choosing the window exceeded?
Old 29th August 2013, 10:22 PM   #14
Gated responses of the "naked" version 0-75, nearfield-CSD
I'm going to couple it to a very soft-sounding bass diaphragm, since coupling it to something hard always sounded untolerably harsh.
Any affordable driver that goes in the Spendor/Harbeth direction? I find Polypropylen quite muddy, and glueing it is not easy.
Old 30th August 2013, 01:42 PM   #15
The device coupled to an iron ring to simulate a heavy daphragm (less distance than the other measurements).
Seems that I should be able to run pretty much everything up to 25 kHz.
building one's own diaphragmHide this!Advertise here!
Diaphragm coating Bazukaz Planars & Exotics 24 9th October 2016 11:41 AM
HDPE diaphragm Coffee Planars & Exotics 11 6th March 2007 02:00 PM
Diaphragm thickness Bazukaz Planars & Exotics 1 24th November 2005 01:20 PM
acoustat diaphragm Williams Audio Planars & Exotics 4 4th October 2005 07:54 AM
