A Speaker that Kicks Butt in Large Spaces - Page 2 - diyAudio
Old 20th June 2013, 10:48 PM   #11
freddi is offline freddi  United States
freddi's Avatar
look at the difference at 1/24 octave between the old Karlsonette copy with small rectangular vent and the Acoustic Control coupler with its tapered rear profile and sizeable (~27 sq.in.) vent
one of the better response graphs I've seen was from a 0.8 scale K15 - might be good to have just a little bit of the lowpass board stick out to allow experimenting with front shelf depth.
Old 20th June 2013, 10:57 PM   #12
freddi's Avatar
when I ran an early production BetsyK in the K12 (Karlsonette), it was surprising how loud the bass could be without much if any visible cone movement - but after the first song at a goodly (live) level (Paul Janda might argue..) BetsyK's leads fell out of the eyelets. I've run a Visaton BG20 in a slit-vent K12 copy with pretty good result and nice tone for a cheap (~$27 at Partsexpress) fullrange speaker.
Karlson's can have a lot of adjustments - lowpass/port position-type including de-Q-ing vents/aperture adjustments, etc.
Is your K15 model flexible enough to adjust only the rear chamber volume without bothering other parameters? - it would be interesting to see trends for certain drivers as the rear chamber is varied. It also would be cool to see trends with only the front chamber varied.
Old 20th June 2013, 10:58 PM   #13
GM is offline GM  United States
GM's Avatar
Originally Posted by freddi View Post
had to look at one of my blonde K15's - their stock vent is 8.875" tall x 4.5" wide.
Hey Freddy, WRT the 4.5" width, what about this vent update you sent me ages ago?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th June 2013, 11:28 PM   #14
xrk971 is online now xrk971  United States
xrk971's Avatar
When yo say only vary the rear chamber volume, do you mean keep the CSA of the back shelf gap and vent port constant? It can be done by adding a phantom volume to either the lower driver chamber and or the upper chamber or both. Or I can simply make the cabinet width change which alters volume and compensate by reducing the shelf gap CSA.
Old 21st June 2013, 12:14 AM   #15
IG81 is offline IG81  Canada
IG81's Avatar
I had a K12/Karlsonette copy, blocked its regular horizontal vent and introduced a rough rectangular vent with only around 7 sq.in. or so area - that seemed to cause quite a suckout. Vent placement probably matters somewhat besides vent area.
When I lowered the tuning on my SK8 by blocking ~2/3 of the vent with some dense foam, the expected effect happened around and below 100Hz, but the initial larger vent area seemed to fill more of that first large dip in the "W" region. I don't remember the exact figures, but tunings were ~67Hz down to ~60Hz or so. I preferred the lower tuning as it is more compatible to my room acoustics.
IG
Old 21st June 2013, 01:45 AM   #16
GM's Avatar
Yeah, lowering Fb also lowered its 3rd harmonic dip and the lower you go, the deeper/wider it gets. Not many 'free lunches' in audio design.
GM
Old 21st June 2013, 01:47 AM   #17
GM's Avatar
What's needed is a hybrid K with a Danley DTS concept tapped horn mated to a high tuned K15 or similar.
GM
Old 21st June 2013, 01:55 AM   #18
xrk971's Avatar
What's a Danley DTS ?
Old 21st June 2013, 03:01 AM   #19
GM's Avatar
It's a type of tapped horn that offsets the driver to fill in its 3rd harmonic dip: Danley DTS-10 "Super Spud" DIY kit
GM
Old 21st June 2013, 07:01 AM   #20
freddi's Avatar
hi GM - in 1956, Karlson published an update of K15 narrowing the vent and both shelf gaps- - IIRC it had little effect on the bottom. A tight aperture gap can affect the tone. Carl experimented with a variety of apertures but did not publish response. K15 should be a lot cleaner than some horns.
here's a 15 inch Yorkville USC1 horn I purchased new compared to a simple K the size of K15 - note the horn's H2 is over 20dB higher than the Karlson and H3 10dB higher than the Karlson. The 1-sheet K was a lot lighter too. That Yorkville cost me quite a bit - never used it again after the testing. The Karlson type was loaded with an Eminence 18 which I bought for $90 having qts ~0.26, fs ~32 mms 103g
Yorkville description http://www.fullcompass.com/product/3...FWlo7Aod1gQABg
Dipoles/Ripoles and small spaces? REDSKIN Subwoofers 2 30th August 2008 09:59 PM
Self-Building Battery, For Microscopic Spaces Nordic Everything Else 0 19th February 2007 10:45 AM
8" Bolt sub kicks butt MikeR Multi-Way 0 9th May 2004 11:32 AM
midrange for kicks caz Multi-Way 10 28th April 2004 06:59 PM
Copyright 1999-2017 diyAudio
