8" Radio Shack Driver
Old 9th June 2013, 04:57 PM   #1
Stvngale is offline Stvngale  United States
Default 8" Radio Shack Driver
I have a pair of new Radio Shack drivers catalog #40-1043. Rated at 25 W, 50W peak, 50-18,000hz, 8 oz. magnet, 90db sensitivity, 8ohm impedance. They are a paper cone, foam surround with a whizzer cone.
I am looking for suggestions for enclosures for these speakers. I will probably be using a little T-amp to drive them, with my computer or I-pad as input. Any ideas or suggestions would be appreciated.
Old 9th June 2013, 05:08 PM   #2
kvaal is offline kvaal  Norway
Lowther Club Of Norway - The Voigt Pipe
Probably the best sound you can get from this driver.
Old 9th June 2013, 05:27 PM   #3
Wow, very simple design. Thank you.
Old 9th June 2013, 07:58 PM   #4
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
Oh, please! No!
That is a truly awful design, even for the original Lowther drivers. It's been years since I've looked at Radio Shack drivers, but I am sure that someone, probably GM, has a better design. Do some searching.
Bob
Old 9th June 2013, 10:36 PM   #5
GM is offline GM  United States
GM's Avatar
Sorry, got nothing on this driver, but if it's anything like the 40-1044, it's best suited for use under a vehicle's dash or rear seat deck.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 10th June 2013, 09:52 AM   #6
Originally Posted by Bob Brines View Post
Oh, please! No!
Bob
Whats wrong with this design?
Old 10th June 2013, 11:50 AM   #7
Bob Brines's Avatar
1. It doesn't go a low as a properly designed TQWT can.
2. The huge suck-out 200-300Hz cannot be stuffed out.
3. the FR plot in the upper bass/lower mid is a roller coaster.
Bob
Old 10th June 2013, 01:19 PM   #8
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Bob,
You have a Voigt pipe design for a RS 1354 driver that looks quite good. Could this be scaled up for the OP's 8 inch driver based on your suggested scaling rule of thumb? Throat set as Sd and mouth area set as 4xSd?
https://mywebspace.wisc.edu/jstalnak...eakers/#Brines
Having no TS parameters available prevents one from simulating this box. But it might not be a bad start? Is the main difference between your Voigt pipe design and one suggested above is the terminus area?
Old 10th June 2013, 02:01 PM   #9
GM's Avatar
FWIW, I have measured specs of many RS 8" drivers and most of them have a Qts between 1.15-2.45..........
GM
Old 10th June 2013, 03:44 PM   #10
chrisb is offline chrisb
Originally Posted by xrk971 View Post
Bob,
nostalgia time eh, Bob? you've come a long way since 2001
kinda burnt out - taking a break
8" Radio Shack DriverHide this!Advertise here!
What to do with "Vintage" Radio Shack Speakers Doug R Full Range 12 7th December 2012 10:39 AM
Radio Shack "Little Rat" Battery powered phono preamp. tweakk Swap Meet 2 6th June 2011 09:38 PM
Realistic/Radio Shack 12" Woofer PBS Multi-Way 1 7th July 2010 02:40 PM
Radio Shack 40-1285D 6" FR pjanda1 Full Range 7 2nd October 2007 01:39 AM
Radio Shack RS 40-1271 8" Full Range Driver gmilitano Multi-Way 27 4th June 2005 03:23 PM
