The PANPIPE (Pentahorn) BLH Speaker - diyAudio
Old 29th May 2013, 05:49 PM   #1
xrk971 is online now xrk971  United States
xrk971's Avatar
Default The PANPIPE (Pentahorn) BLH Speaker
I originally posted this idea in the DBLH thread here (DBLH)which was for a Double Back Loaded Horn wall-mount speaker. This is clearly a different animal as it is not wall mounted and has many more pipes. Below is a repeat of original post to kick things off.
The speaker is sort of a conventional 'Scoop Bucket' type BLH in appearance. However, the cabinet is divided (top to bottom) into 5 separate horns, each tuned to a different frequency, and each fed by a common "throat" plenum connected to a driver chamber. The speaker is designed from scratch by individually optimizing the lengths, throats, mouths, and chamber volume to produce a relatively flat response that has deep bass extension, with each horn resonance peak offset from its neighboring horn resonance peaks.
Here is the simulation using AkAbak of a 5 horn BLH with the horns front facing and stacked next to each other at the bottom of the cabinet. I have not worked out the full physical dimensions of the cabinet and what it would take to fold and route the passages yet. I am assuming the cabinet will be 25 in wide to accommodate qnty 5 x 5 in wide horns. The longest horn is 144 inches and each successive one is multiplied by 0.9, 0.8, 0.7, and 0.6 factors. Horns mouth 1 (longest) will be 12 in tall x 5 in wide, the rest are all 8 in high x 5 in wide. The throats for each horn were optimized and ended up as 2 in, 0.7 in, 0.7 in, 1.0 in, 0.7 in (times width of channel of 5 in). A common throat leading from driver chamber to plenum manifold of multiple throats is 4.0 in to 5.0 in x 5.0 in long (times width of channel of 5 in). The driver chamber is 18 liters. The driver is the W5-1611, and all calcs were for 1 watt input measured at 1 meter away. The first plot shows the horn output for 1, 2, and 3. The second plot is for horn output 3, 4, and 5. The third plot shows the total output of all horns combined with driver direct radiation (black, red is longest horn, green is shortest horn). As you can see, there are lots of resonance peaks for each horn but the spacing is evenly spread out as expected and the amplitudes are pretty well balanced. I imagine that with damping added to the driver chamber, and maybe a little in the common plenum section these peaks will all be blended into one smooth output. The fourth plot is the impedance, fifth plot is the driver cone displacement, and sixth is impulse response.
Any feedback on this design from folks would be appreciated. Is this just too much trouble to get a smooth horn output? I think the advantage will be that the sound from this speaker will have all the benefits of immediacy in deep bass response (the impulse response is relatively quick compared to a bass reflex or MLTL that will have significant delay). So the sound should be more natural. The 30 Hz bass extension is quite impressive with controlled cone motion just at the limit of the driver's range.
This is response from horns 1(longest) to 3:
This is response from horns 3 to 5 (shortest):
This is the combined response including driver direct radiation (black) and longest (red) and shortest (green) horns:
This is the impedance:
This is the driver cone displacement:
And if you are interested in building this and don't want to yet spend $50 in a TB W5-1611 driver, very good results can also be obtained with a budget Monacor SP50X driver ($20 at MCM http://www.mcmelectronics.com/produc...P-50X-/55-4636) as shown below (thanks to @Ryani for pointing me in this direction). I will provide detailed build plans shortly. Foam core seems to be the way to go for test build and if you like it - go with wood.
Let me know if you are interested in a build and I will try to draw up plans soon.
Here is the freq response with the SP50X (no changes to cabinet):
Old 29th May 2013, 06:47 PM   #2
ryani is offline ryani  United States
Looking forward to see the plans X.
Old 29th May 2013, 08:10 PM   #3
This speaker DIY thing, it's pretty addicting!
mikejennens's Avatar
Looks interesting. I'll be following this thread and might just try this build.
Mike
Jolida SJ502A, Squeezebox Touch, Paul Carmody's Sunflowers, Jeff Bagby's Continuums; Planet 10 HiFi's MarkAudio A 7.3 Frugalhorns and MarkAudio CHP-70s, Bjorn's PS95 TABAQs
Old 29th May 2013, 09:39 PM   #4
Speakerholic
Cal Weldon's Avatar
No thanks, I already have a Penthorn.
planet10 needs your help:
Let's help Ruth and Dave
Old 29th May 2013, 09:44 PM   #5
xrk971's Avatar
Cal,
I wish I can hear your Penthorn (or the Pontifs as they were called). As I recall you said they were pretty loud. What is the path length of your penthorn channel from driver chamber to mouth?
Old 29th May 2013, 09:51 PM   #6
Speakerholic
Cal Weldon's Avatar
Oh gosh, I will have to look that up when I get home. I'm leaving the office soon. They are still playing in the livingroom but they don't sound as good as the spirals I don't think. Loud? OMG yes but I think that's mostly due to the drivers not the cab.
As far as the name goes, I will stick with the original if that's ok. I like the name Penthorn.
Pentahorn on the other hand is almost as good. You keep that one.
I don't want to crowd this thread I just wanted to poke my nose in and say hi.
Old 29th May 2013, 10:08 PM   #7
xrk971's Avatar
Cal,
Penthorn, Penthouse, what's the difference... Not crowding at all - you are welcome to poke around and add all you want. I think Panpipe may be closer to what this is because of how the horns are all next to each other in a stack like a Peruvian panpipe. I guess it would look more like it if the mouths went out the top. I need some time to draw this up.
Old 29th May 2013, 10:43 PM   #8
Speakerholic
Cal Weldon's Avatar
The measurement of the Penthorn:
Depth of channel - 4"
Length from throat to beginning of mouth flare- 30"
Length overall - 38"
Width starts at 1" and increases to 2" and start of horn flare.
Old 30th May 2013, 05:14 AM   #9
Awesome. This is my new favourite thread
Regards /Bo
Old 31st May 2013, 05:03 PM   #10
cogitech's Avatar
Lurking with interest!
what causes this to happen with a BLH? gafhenderson Full Range 5 26th February 2012 04:23 PM
Jensen BLH Zene Gillette Full Range 7 5th February 2012 05:07 PM
Highish Q FR speaker in BLH enclosure? Mosquito Full Range 9 20th October 2011 05:06 PM
Back Loaded Horn (BLH) Full Range Speaker Build jgray Full Range 10 6th June 2011 03:25 AM
BLH for physically deep speaker? freddi Full Range 0 17th April 2007 09:08 PM
Copyright ©1999-2017 diyAudio
