your experiences of FR speakers in open baffles - diyAudio
Old 22nd May 2013, 10:06 PM   #1
Bill poster's Avatar
Default your experiences of FR speakers in open baffles
wd love to hear from anyone who has used various FR's in open baffles or something similar, pros and con's etc. I'd like to try making a 'simple' design over the next two months(if i have enough spare cash), a 2-way with the woofer 'boxed'
I've seen the small Fostex's used but I'm wondering about output/spl. Also if its beneficial to put some sound absorbency behind the FR to preserve imaging.
Old 23rd May 2013, 08:05 AM   #2
norman bates's Avatar
I prefer a foam box around the back of an open baffle.
Unless it is an electrostat, then I'd demand it to be 6' from the front wall.
bastanis prometheus mkII
6moons audio reviews: Bastanis Prometheus Mk.II
see it half way down.
Un-boxy is a difficult sound to describe.
Cone size and drivers, that's up to you.
Norman
Old 23rd May 2013, 08:13 AM   #3
picowallspeaker's Avatar
Only felt, Thx
Old 23rd May 2013, 01:09 PM   #4
xrk971 is offline xrk971  United States
xrk971's Avatar
I tried an OB with a Vifa TC9FD mounted on foam core, glued to a large cardboard "L-wing" OB made from a large cardboard box. The Vifa is actually the preferred FR driver for a very nice OB design called the Manzanita Fast, fun, Inexpensive OB project. I used a boxed subwoofer from an existing stereo and bi-amped with no cross-over. It sounded very nice - open sounding is the best way to say it. It takes too much room though and I never got around to building a proper wood baffle. My post describing this is here: Foam Core Board Speaker Enclosures?
I think line-level cross overs between the pre-amp and power amp with bi-amping is the way to go otherwise you spend a lot of money on huge inductors required for the cross over. It costs just as much if not more than getting a second class D amp.
Old 23rd May 2013, 03:40 PM   #5
thanks for the replies; Norman I looked at the link, cheers for posting. i wanted to either mount the FR in an open ended short stuffed tube or similar, to absorb some of the back wave
xrk971 I was planning to go for a passive x/o and use same cone material drivers(alu or paper). This way i was hoping a simple 1st order wd suffice, altho I'm worried about overlap from the bass driver muddying the midrange of the open baffle FR. As its only a 6dB slope, my idea was to pull the x/o out by half an octave, (300-450hz)to create a little bsc and reduce overlap. Otherwise I'd have to look at mixing a 1st high pass w 3rd low pass ..
Old 23rd May 2013, 07:04 PM   #6
I think there was a project on partsexpress where the midrange was in a round tube exhausting through the speaker box, and the tube was full of acoustuff. That way you can have the non boxy sound.
Crossing it will be tricky.
Norman
First Open Baffles mortron Full Range 10 9th December 2012 01:11 PM
New open baffles hurdy_gurdyman Multi-Way 3 26th September 2007 02:22 PM
Clear acrylic speakers - any ideas? (Also, how should I make B3s open baffles?) Spasticteapot Full Range 17 22nd October 2006 04:19 PM
$7 open baffles... planet10 Full Range 31 8th May 2005 07:45 AM
Open Baffles :- ) brianon Multi-Way 17 3rd February 2004 08:13 PM
Copyright 1999-2017 diyAudio
