Decware DNA Horn
Decware DNA Horn
Old 6th May 2013, 07:43 PM   #31
bcmbob is offline bcmbob  United States
Good call chrisb, I'll work on getting the O.K. before proceeding.
Was just about to make the first cut.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 6th May 2013, 08:00 PM   #32
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Decware DNA Horn
Originally Posted by xrk971 View Post
note it is actually 0.75 in thick even though called half inch. Go figure.
That's prolly a misprint. I've never heard of 0.5", only 0.75" and up, from your local building supply stores.
planet10 needs your help:
Let's help Ruth and Dave
Old 6th May 2013, 08:11 PM   #33
I have the board at home now and the calipers read 19/32 consistently. Closer to 5/8 than 1/2".
Bob M.
Old 6th May 2013, 08:14 PM   #34
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
Decware DNA Horn
This is a DIY for personal use with dimensions estimated from publicly available drawings provided by the designer - there is no limitation on whether or not you can do this. Cut away...
Old 6th May 2013, 08:15 PM   #35
Speakerholic
Cal Weldon's Avatar
Decware DNA Horn
That's 15mm. Didn't know they made it.
Old 6th May 2013, 08:18 PM   #36
Sounds good. If there is any problem I'm sure they will let me use them with my ACA in the Big House.
Bob M.
Old 6th May 2013, 08:18 PM   #37
Got Foam?
xrk971's Avatar
Decware DNA Horn
I don't think it is a misprint, I bet the nominal dimension is the thickness of the extrusion die. Once the wet foam is extruded it continues to expand before hardening at whatever thickness it happens to be based on local ambient conditions like temp, barometric pressure, humidity, etc. The only number they can quote is the extrusion die they use. As the 0.594 in thickness is neither here nor there - varies lot to lot probably... ???
Old 6th May 2013, 08:30 PM   #38
Speakerholic
Cal Weldon's Avatar
Decware DNA Horn
Dunno,
I only deal with the thick stuff and it is dimensionally correct. (it has to be for design purposes) and I didn't think it came less than 3/4", that's all.
Old 6th May 2013, 08:46 PM   #39
chrisb is offline chrisb
Dunno,
I think you'll find plywoods vary much more over their nominal dimensions than say, sanded MDF, or insulation panels
like my mind, this space intentionally blank
Old 6th May 2013, 08:54 PM   #40
As I corrected in my earlier post, all I had to do was look at the Decware website to find that measured plans are available @ $20 - a reasonable figure
The design certainly looks less complex and practical than his corner horn design of over a decade ago. Those I acquired a set of, but never got around to building - as much due to the absence of a suitable room that could be dedicated to their use as their complexity. Well, OK, they're not the simplest design either, but the little DNA looks fairly straight forward.
Decware DNA HornHide this!Advertise here!
Decware Corner Horn plans for Fostex FE167e vaughn Swap Meet 2 17th April 2012 11:39 PM
FS: Fostex FE206E (Decware modified) backloaded horn with Karlson Slot $299 bbaker6212 Swap Meet 4 24th September 2007 04:34 PM
McCormack DNA-500 one channel out kaboom Solid State 12 20th June 2006 01:41 PM
FS: Wicked One bass horn (decware design) cm961 Swap Meet 0 11th August 2003 03:17 PM
Decware DIY Bandpass Horn subs Will Subwoofers 2 15th October 2001 10:14 AM
