Decware DNA Horn
Decware DNA Horn
Old 23rd May 2013, 01:35 AM   #171
bcmbob is offline bcmbob  United States
Thanks for the offer, I'll get the data together and send it to you. In the picture the JC-2 Pre is pushing the ACAs. It sounds good at rather high volume and using a pre may influence what you select as a driver. Just a thought.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 23rd May 2013, 01:43 AM   #172
BP1Fanatic is offline BP1Fanatic  United States
BP1Fanatic's Avatar
Your setup is awesome! I really like how you built the amps to power the speaker too. I guess video is next???
Old 23rd May 2013, 01:44 AM   #173
xrk971 is online now xrk971  United States
xrk971's Avatar
Decware DNA Horn
Bob,
Do you have photos of your ACA build posted somewhere? Your heatsinks appear to be dc to dc converter half bricks which I considered using because they are inexpensive but folks on the ACA thread said they would get too hot. I think they should dissipate 10 watts ea no problem.
Old 23rd May 2013, 01:58 AM   #174
xrk971's Avatar
Decware DNA Horn
Bob,
I was thinking how you say this sounds pretty good for the price. It's rare to have a true HiFi setup with a Steve Deckert BLH speaker powered by a Nelson Pass single ended class A amp for under $100! I bet it sounds better than many $700 stereos out there. Nice job.
Old 23rd May 2013, 01:59 AM   #175
I posted somewhere but don't have the link handy. I'll take the risk of hijacking the thread and repost till I find it. There was some text but here are the pics. Two xeon heatsinks per amp.
Bob M.
Old 23rd May 2013, 02:03 AM   #176
xrk971's Avatar
Decware DNA Horn
Hijack away! Are those surplus pc cpu heatsinks? I like the angle bracket as main structure and heatsink base. I am thinking of using a Pentium 2.4 GHz cooler fin.
Old 23rd May 2013, 02:09 AM   #177
Thanks all for the complements. Yes, PC stuff - I got bunches of them while building a render farm with a some dual processor surplus motherboards.. They came from eBay about four years ago. There are still some good units there at a bargain.
I salvaged four 8' links of 3" X 3" X 1/4 structural aluminum from my former employer. I'm gonna be lost when I run out. !!!
Bob M.
Old 23rd May 2013, 03:19 PM   #178
xrk971's Avatar
Decware DNA Horn
That's a nice score of aluminum angle stock. Metalsdepot.com sells 8 ft of 3x3x0.25 angles for $91 ea. Another option for amp structures with lots of surface area for heat transfer are Bosch rails.
Aluminum Structural Framing - Aluminum Structural Framing - aluminum, custom worktable, ergonomic workstation, extrusion, framing, framing components, industrial framing, lean manufacturing, modular construction, profiles, structural framing, t-slot
They build clean room workstations and Porsche assembly lines with this stuff.
They actually are not that expensive compared to plain channels and let you connect things with T-slots. They come in many profiles. http://www13.boschrexroth-us.com/cat...s/section2.pdf
Maybe a 4 in long free eval-sample will be a great heat sink?
OK, we will get back to our regular programming now of the DNA horn. Actually the angles can make good out rigger legs... so it is related
Old 1st August 2014, 09:26 AM   #179
AmadeusMozart is offline AmadeusMozart  New Zealand
How would the FE167e fit into the DNA horn? Horn length seems to be about right and also the coupling chamber / bass reflex chamber (it is a hybrid after all) is right for the FE167e . It certainly is more reasonably sized than the Replikon (narrow the FP163 from 30 to 20 cm and you are almost spot on) and I do like the rear horn opening.
Thanks.
Old 1st August 2014, 09:37 AM   #180
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Decware DNA Horn
I don't think it isnear big enuff.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Decware DNA HornHide this!Advertise here!
Decware Corner Horn plans for Fostex FE167e vaughn Swap Meet 2 18th April 2012 12:39 AM
FS: Fostex FE206E (Decware modified) backloaded horn with Karlson Slot $299 bbaker6212 Swap Meet 4 24th September 2007 05:34 PM
McCormack DNA-500 one channel out kaboom Solid State 12 20th June 2006 02:41 PM
FS: Wicked One bass horn (decware design) cm961 Swap Meet 0 11th August 2003 04:17 PM
Decware DIY Bandpass Horn subs Will Subwoofers 2 15th October 2001 11:14 AM
