Enclosure Suggestion???
Old 17th April 2013, 11:59 PM   #1
fringy75 is offline fringy75  New Zealand
fringy75's Avatar
Default Enclosure Suggestion???
Hi all.
I picked up a couple of widerange speakers from the New Zealand version of ebay, specs are below. Manufacturer is unknown. Can anyone suggest a enclosure that they feel would work? I also have no other t/s detail.
One pair of Neodymium magnet, paper cone Taiwanese-made wideband speakers.
Similar to Fostex fullrange speakers with a balanced and smooth frequency response. Reports had some prefer them to Lowthers.
106mm driver faceplate
94mm baffle hole size
Approx 89dB efficient
68hz - 20Khz
Imp: 4ohm
Fs: 68Hz
Qt: 0.48
Vas: 7.68 l
Xmax 2mm
10w rated, 15w music
Surround: PU
Cone: Paper
One of the advantages of being disorderly is that one is constantly making exciting discoveries.
Old 18th April 2013, 12:50 AM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
What basic shape of cabinet are you thinking about?
Tall and narrow
Wide and shallow
Standard stubby
Or...?
planet10 needs your help:
Let's help Ruth and Dave
Old 18th April 2013, 01:12 AM   #3
fringy75's Avatar
Hi Cal.
To be honest i don't mind, WAF in the room that my audio sits in is not an issue.
I have an wide taste in music, so could be classical one minute followed by Pink Floyd! although saying that I do have a preference for female vocal jazz.
Room is 5 metres wide by 8 long by 2.4 high and will be run from a Topping TP30 T amp.
Old 18th April 2013, 01:23 AM   #4
Speakerholic
Cal Weldon's Avatar
Sounds like a Cornu candidate.
http://www.diyaudio.com/forums/full-...w-you-can.html
Old 18th April 2013, 01:29 AM   #5
fringy75's Avatar
Thanks Cal. I will take a read of the 75 pages of posts
Old 18th April 2013, 03:59 AM   #6
Speakerholic
Cal Weldon's Avatar
Only 19 pages if you set it to 40 posts per page.
Old 18th April 2013, 04:32 AM   #7
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Originally Posted by fringy75 View Post
Hi Cal.
You have musical tastes very similar to mine. I will agree with Cal and suggest the Cornu for this driver (standard 28 in size x 4.5 in deep) and also another option is to go with a FH3-like design. FH3-inspired Foam Core Mini Build I had very good luck scaling the FH3 down to work with the Vifa TC9FD. Btw, the frame on this driver looks just like a Vifa/Peerless (probably a custom run by Peerless for this company). The FH3-like design will have better spatial imaging soundstage but Cornu will fill space better and have wider sweetspot. Both are great for female vocals. Good luck.
Old 18th April 2013, 04:50 AM   #8
Speakerholic
Cal Weldon's Avatar
Cornu.
It makes sense in so many ways unless you are building fully from wood and then the options other than Cornu are endless. I think it's the frontrunner due to it's ability to have a working model in a short number of hours. Due to it's nature, it's not going to sound a lot different in a wood cabinet than if it's foam core with wood baffles. That's hard to say with other alignments. Hey man, you're the genius here, run with it.
Old 18th April 2013, 07:10 AM   #9
hm is offline hm  Europe
hm's Avatar
Default small driver
Hello,
may be the CORNET would be a choise,
bass down 34 Hz, tube amp possible,
look measurements and feedback:
http://www.hm-moreart.de
Old 18th April 2013, 07:29 AM   #10
fringy75's Avatar
Thanks guys for the suggestions. Xrk971, I have read the whole thread on foamcore enclosures, and I have to admit that they do sound like fun
The great thing is that I can always build multiple enclosures and play.
Enclosure Suggestion???Hide this!Advertise here!
Speakers enclosure suggestion, before X-mas PLEASE!!! sagamotto Full Range 2 11th December 2012 04:26 AM
Subwoofer enclosure Non-parallel enclosure to reduce standing waves qguy Subwoofers 4 4th July 2011 09:35 PM
Gainclone enclosure style suggestion kwakeham Construction Tips 2 14th September 2010 10:49 PM
Enclosure suggestion/questions santiu Tubes / Valves 12 29th December 2005 06:20 PM
Suggestion for PHY-HP KM30 enclosure cmt42001 Multi-Way 3 26th March 2004 11:22 AM
