Full range speakers for Homecinema purpose Full range speakers for Homecinema purpose - Page 9 - diyAudio
Old 4th May 2013, 01:52 AM   #81
Bob Brines is offline Bob Brines  United States
Bob Brines's Avatar
This is the first chance I have had to compare the A7.3 against the A12P in the same venue. This is the setup in Room 217 at LSAF. (Y'all come down tomorrow!) The A12P absolutely smokes the A7.3 in every way. It is cleaner, clearer, goes higher, goes lower and is more dynamic. I used to love the A7.3's. They were the best I had ever heard. Until the A21P's. For sure I will get a pair of A10P's when they become available.
Bob
Old 4th May 2013, 02:07 AM   #82
jimbro is offline jimbro  United States
Just when I thought I was through buying drivers...
Old 4th May 2013, 02:09 AM   #83
zman01 is offline zman01  Bangladesh
Fun of DIY... at times I feel it should come with a disclaimer.
Old 7th May 2013, 03:17 PM   #84
talaerts is offline talaerts  Belgium
Coming back to the modern coaxial Beymas. They are indeed not cheap and the Neodymium magnets must play a role there. Well, I now notice that they have just released ferrite versions of them. I assume that these will be significantly cheaper but I haven't found prices yet.
From the Beyma news page:
"Extending the coaxial family, Beyma introduces four new ceramic magnet speakers; the new 5CX200Fe and 6CX200Fe are designed for full range applications, with extended low frequency response and accurate high frequencies thanks to the new and exclusive PM4 annular diaphragm. An excellent choice for high performance compact bass reflex cabinets. In the bigger range, we introduce the 12CXA400Fe and 15CXA400Fe, with common ferrite magnet design the new models are designed for top performance in the whole audible range. The typical application of these models are the stage monitors, but thanks to the outstanding response from the bottom to the top of the spectrum, more possibilities of application emerge (the neodymium versions are already installed in some reference broadcasting and recoding studios around the world)."
And here is a relevant fact sheet:
http://profesional.beyma.com/ingles/pdf/5CX200FE.pdf
Old 13th August 2013, 12:39 PM   #85
Stanphink is offline Stanphink  Wales
I'm very interested in these too.
You can get them here
Old 26th November 2014, 12:40 PM   #86
brookhart995 is offline brookhart995  United States
Hello all,
Need some help on a center channel enclosure. I am going to use a Mark Audio Alpaire 10.3 driver and would like some advice on a suitable box. This will sit in the open on top of a very large TV stand so size is not a concern. I would prefer that the driver mount center line in the enclosure and ported would be preferred. I even considered using a design similar to Jim Griffin's MLTL tall floor enclosure that is about 47" tall! If that gives you any indication of the size I have considered. Thanks in advance for any assistance.
Old 27th November 2014, 12:48 AM   #87
brookhart995,
Your center speaker is going to stand vertical or you are going to place it horizontally?
Among horizontal options, variations of P10 MarKen enclosures come to mind... afaik a few have been built of the Alp 10.2
Your front are also Alp 10.3?
Old 27th November 2014, 01:19 AM   #88
I knew I forgot something. I will set it horizontally.
Old 27th November 2014, 09:03 AM   #89
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
One of the persisting errors in home theatre setups are horizontal MTM's, but if you only use one speaker it should be ok. However, with a narrow baffle (vertical setup) you will get better horizontal dispersion, which is what you want unless you are alone in front of your screen.
Btw, because full ranges always start beaming at fairly low frequencies, they are not the best for center channels anyways.
Old 27th November 2014, 01:03 PM   #90
Bob Brines's Avatar
Since the OP appears committed to A10.3's for mains, he is also pretty much committed to A10.3 or A7.3 for the center. Ideally, all three speakers should be identical, but at least the same vendor. Placing a M-T speaker horizontally also presents polar problems, since the main lobe is not centered at the XO frequency.
I personally favor phantom center channel, but in this case I would recommend a Q=1 sealed box assigned as "small".
Bob
Full range speakers for Homecinema purposeHide this!Advertise here!
Full range speakers the way to go? dave123456@mail Full Range 18 24th September 2013 10:52 PM
Active filtering or new cross-over for DIY 15 inch homecinema speakers? vandevoordekoen Multi-Way 42 11th October 2012 01:28 PM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
what are full range speakers? legendaryfrog Full Range 10 10th November 2006 01:35 AM
Copyright ©1999-2017 diyAudio
