Full range speakers for Homecinema purpose
Old 24th April 2013, 12:26 AM   #41
Overkill Audio is offline Overkill Audio  United Kingdom
Overkill Audio's Avatar
Default Home Cinema with full range
IMO...
Line array full range speakers are fab for home cinema.
But for real home cinema you are always going to need at least one sub, better with two or even three, corner loaded, sealed 60 litre to 70 litre 20mm to 25mm birch ply or 10mm alloy.
Try a 12 inch Beyma 12SW 1300Nd with 500 watts minimum and a bit of room Eq and you will be in heaven!
I agree with Norman on the point of using identical drivers all round.
I use 16 BMR drivers per side in line arrays for my front left right, 9 BMR's for the centre channel, and 4 BMR's per side at the rear.
Seamless seamless, seamless, really great effects on movies and lovely with music too.
Cheers
Derek.
File Type: jpg Christmas Eve 2012 ..Hogworts! 096.jpg (291.5 KB, 392 views)
Old 24th April 2013, 09:13 AM   #42
talaerts is offline talaerts  Belgium
I contacted a French compagny for the Beyma 5CX200NDNE they are available 181Ђ each (transport included), this is still expensive for my project, even if the price seems very good compared to other sellers.
then remains the Fostex (FF or Sigma) & Mark Audio (CHR 70 or Alpair 12) although quite difficult to find a reseller in France (do guys knows one?).
Well, the Beymas -while not cheap- are inline with your original budget, for the front 3 channels at least, a bit above for the rear channels.
I still find these a very interesting choice for a good quality home cinema, more realistic than a fullrange solution (and I do like FR drivers, for music that is). The main reasons being that they will be near indestructible in a home cinema setting yet (likely, I haven't heard these) still offer very good quality for music use, and they have much better off axis dispersion than FR drivers which is pleasant when multiple people watch a movie.
Old 25th April 2013, 08:03 AM   #43
jayce996 is offline jayce996
the worth with the Beyma is that there is no feedbacks nor builds already done with them, or at least i did not find them
Old 25th April 2013, 09:39 AM   #44
I found a russian site with filter and box design for it. And, for what it is worth, it had an award during a professional trade show.
From my experience with the brand, the sound is likely very good.
Old 25th April 2013, 10:05 AM   #45
Hi talaerts,
can you share the link please?
thx in advance
Old 25th April 2013, 11:40 AM   #46
ODougbo is offline ODougbo  United States
Great looking speakers (and daughter (?) btw).
Q. With all the driver coils - Don't they act like a inductor and attenuate the treble?
Originally Posted by Overkill Audio View Post
IMO...
Cheers
Derek.
Old 25th April 2013, 09:59 PM   #47
Default Multiple driver inductance
Hi Doug,
Thanks, yes my daughter is a real cute kid, her twin brothers are cool dudes too...Going to be a bit crazy round here when they are all teenagers...Gulp!
Re driver inductance, basically its not a problem, in fact using multiple drivers gives you a much cleaner and more open top end ( and midrange too).
It sounds even more extended than a single driver, but measurements show no real difference, only tiny plus or minus driver tolerance variance.
The reason the mid and top sound way better than a single driver is that the each cone in the multiple driver speaker is only moving a fraction ( a sixteenth in this case) as much as a single driver cone would for the same SPL.
This basically eliminates all the problems that single full range drivers have such as : no percussive impact, no bass, high distortion at any decent volume, confused and muddled sound with complex music...etc. etc.
Traditional line arrays have their own problems, esp. two or three way arrays using separate lines of tweeters, bass mids and or woofers. The crossovers can be a real nightmare, and both horizontal and vertical interference can be problematic as well as off axis lobes and rear wall bounce.
Also fake or " mini arrays" i.e. 3 or 4 feet lines of drivers which are the worst of all worlds, wont bore you here but suffice to say you are better off with a good old 3 way rather than a pint sized array.
Hope this helps and all the best
Derek.
Old 26th April 2013, 04:37 PM   #48
Originally Posted by jayce996 View Post
Hi talaerts,
thx in advance
Here: Динамик широкополосный Beyma 5CX200Nd, обзор. Портал "www.marvel-pro.ru".
Many pictures of the speaker itself which looks like a serious piece of kit.
google translate can help.
Old 28th April 2013, 06:01 PM   #49
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
another driver which wd work great are Aurasound NS3's, amazing little things
Old 29th April 2013, 12:55 PM   #50
After a long reflexion and budget re-evaluation, i think i'll go with the Beyma drivers.
and so now, final reflexion:
the three models are 5CX200ND , 6CX200ND & 8CX300ND, where the first number is the diameter, and the price is approximately 210€, 220€ & 240€ before negociation, (note that a company was decreasing the price for 5 5CX200ND to 181€ each, transport included)
so the question is the following: which configuration
- 5 (front + center + rear) 5CX200ND or 6CX200ND or 8CX300ND + a Sub (a previously mentionned)
- or 2 Front 8CX300ND + Center 6CX200ND + 2 rear 5CX200ND + a Sub (in order to have better sound in HC & Stereo Hifi)
- or 3 (Front + Center) 6CX200ND or 8CX300ND + 2 rear 5CX200ND + a Sub (in order to have better sound in HC & Stereo Hifi)
Full range speakers for Homecinema purposeHide this!Advertise here!
Full range speakers the way to go? dave123456@mail Full Range 18 24th September 2013 10:52 PM
Active filtering or new cross-over for DIY 15 inch homecinema speakers? vandevoordekoen Multi-Way 42 11th October 2012 01:28 PM
Frequency range of the human voice & full range center channel speakers jwmbro Multi-Way 31 20th January 2008 03:07 PM
what are full range speakers? legendaryfrog Full Range 10 10th November 2006 01:35 AM
Copyright ©1999-2017 diyAudio
