Just found the BIB design - Page 3 - diyAudio
Old 9th April 2013, 07:14 PM   #21
Scottmoose's Avatar
A pipe expanding in a linear fashion toward the terminus is a conical horn; assuming St = 0, then it has a resonant frequency of 1/2 lambda and both odd and even harmonics. An uptapered pipe has a resonant frequency of 1/4 lambda and produces only odd harmonics. There is no such thing as a 1 1/4 wavelength pipe. There are only 1/2 wave or 1/4 wave pipes.
Old 9th April 2013, 07:31 PM   #22
Are you saying 1 1/4 wavelength pipe has never been built before? Or that it can't exist, even as a hypothetical object?
'lambda' is almost always wavelength. What are you using it to mean?
Old 9th April 2013, 08:09 PM   #23
Scottmoose's Avatar
I am rapidly getting the feeling that you know exactly what I am talking about.
There is no such thing as a 1 1/4 wavelength pipe. There are 1/4 wave pipes, or 1/2 wave pipes. That's it. You could create a pipe 1.25x whatever the wavelength of a given frequency is, but that is not a 1 1/4 wave pipe. That is either a 1/4 or 1/2 wave pipe tuned to a much lower frequency.
Old 9th April 2013, 08:39 PM   #24
I don't get the same feeling.
When I refer to "Wavelength", it is a measure of length, and given a speed of sound and rate of Hz, can be converted to and from meters, inches, feet, etc.
When I refer to a pipe being a certain wavelength (1/2, 1/4, 1 1 1/4, etc), I mean it's length is that multiple of whatever wavelength it is understood we are talking about. This might be the Fs of the driver, a slightly lower sound than the driver's Fs as some suggest, or a completely arbitrary wavelength. A 80Hz quarter wavelength tube is also a 160Hz half wavelength tube. In terms of hypotheticals, we can say we are talking about one and not the other, but if we were to physically build both, they'd physically be the same.
Since a wavelength, or any multiple there of, can be converted to inches, and a tube of that number of inches can be constructed, at least in theory. For a reasonable number of inches (less than 100) it is trivial to build such a tube. Hypothetical discussion of how such a tube behaves with sounds of that wavelength can be valid, interesting and important, even if building such a tube for the purposes of amplifying that wavelength is not a viable design.
My main confusion is how a quarter wavelength tube is a viable design - that is based on my knowledge of physics, a closed tube will have a significant void for sound waves with a wavelength 4 times the length of the tube. If that is the case, it is a poor choice for amplifying those soundwaves.
I realize that a TQWT is not the same as a closed tube, but any different way I've tried to think about it leads me to believe it has a void at for sound waves 4 times its length.
I believe driver placement in a BIB or TQWT design is meant to minimize certain harmonics. I have no idea how .217 was chosen as the ideal driver placement, or why this placement performs better than most randomly chosen locations.
Old 9th April 2013, 08:45 PM   #25
Scottmoose's Avatar
I suggest you read the pages I linked to, particularly the many detailed papers on Martin King's site (Quarter Wavelength Loudspeaker Design).
Old 9th April 2013, 09:08 PM   #26
I have. Anything in specific? There is a lot of material here.
Take a look at the graphic on the first page that shows the standing waves. In your head, draw the wave reflections for the red line assuming the "open end" reflects without phase shift. The closed end might phase shift 180 degrees or it might not phase shift at all. Either way, the reflected waves create a void.
Old 9th April 2013, 09:59 PM   #27
Paul Voigt wrote in his patent:
The simplest form of "bass chamber" for carrying this invention into effect is a straight tube, of length just under one quarter the wavelength of the lowest frequency at which efficient working is desired, the diameter being about ... the length, and the tube being closed at one end. The air column contained within the bass chamber is excited by means of a loudspeaker diaphragm applied at some distance from the open end.
For example, for a 64 cycle note [64Hz], a bass chamber 130 cms. long [wavelength is 5.375 meters, 1/4 would be over 134cm)
Is it possible he wasn't trying to use the reflected waves from the open end to build resonance at all? Other parts of the patent (mention of corner placement being radiation into 1/8th of a sphere) hint that he is maybe using the room itself. If he is trying to build resonance similar to room modes and believes 1/4 wavelength will be constructive, stopping just short of that length would be one of the worst things he could do. Perhaps he knew 1/4 length would have a void, and deliberately stopped short of this length to avoid that it? He is definitely writing about mass-loading his driver with the column of air. I also get the impression he is building a tube around a wave several octaves lower than the Fs of the driver he is using.
Is it possible what actually did, what people building TQWT today believe he did, and what people building TQWT are building today rely on completely different physics, even if these designs are all implemented as a tube about 1/4 the length of Fs? Of course any of these designs have properties of a transmission line, a horn and a base reflex and any number of properties (useful or detrimental) that their designer didn't intend. Martin King seems to hint at this last point.
Old 9th April 2013, 10:03 PM   #28
Scottmoose's Avatar
Read Martin's Anatomy of a TL paper first. When you've familiarised yourself with the basic physics, you can then move on to his other material. At present, you appear to be claiming that a quarter-wave resonator does not resonate.
Old 10th April 2013, 03:18 AM   #29
GM is offline GM  United States
GM's Avatar
Is it possible what actually did, what people building TQWT today believe he did, and what people building TQWT are building today rely on completely different physics................
Rooms are 1/2 WL resonators, so to damp a driver's Fs with a 1/2 WL resonator requires it to be 4x longer than a 1/4 WL resonator.
The 1/4 WL resonator has historically been used to damp the driver's Fs impedance. Paul stopped it physically 'short' no doubt because its acoustical path-length is longer, i.e. there is an end correction that must be factored in and if heavy damping is used, then the pipe's physical length must be further shortened to match up to its acoustic path-length.
Nowadays, most folks don't need to tune to Fs to maximize bass efficiency, so one can use the pipe's harmonics combined with driver offset to shape the driver's response. Ditto for 1/2 WL resonators.
No, the physics hasn't changed nor our basic understanding of them.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th April 2013, 01:58 PM   #30
I played with some real tubes last night, and was sadly disappointed. I am able to get resonance at both 1/2 and 1/4 wavelength, but 1/2 is stronger and I only measured +3db. I am sure I can do better with a real enclosure, but I just don't think the design tradeoffs are worth it. Without damping, I get a hall-of-echos effect that I am certain can be minimized but I am not sure can be eliminated, the response graphs I've seen of transmission lines all look a little ragged. Also a thin 7 foot tube that minimizes floor space looks a lot better on paper than in my living room, and a folded tube takes up too much floor space and puts the tweeter at the wrong level. What do I gain for all this? I think I can more/better bass just using a bigger woofer and a sealed box. The cost of the woofer and crossover isn't much when you consider the time and cost to build the box. I am sure transmission lines have a place in the audio world, but probably not for me.
I did read the Anatomy of a TL paper in more detail. There is no explanation of physics, the author even suggests "an undergraduate level vibration textbook" for those like me who don't understand everything before reading the paper.
The wikipedia article is a better introduction, and clearly states the resonance of various cylinders and cones, but does not explain why they resonate.
I guess if I really want to understand this, I need to pick up an acoustics textbook. One idea I had is sound waves are not really sine waves, but more a sine and inverted sine wave together - so the anti-nodes are all the same regardless of phase. This makes a 180 degree phase-shift constructive instead of destructive, and fits everything I've read so far.
Small 2" drivers in BIB design Gugi Full Range 22 16th February 2011 07:01 PM
Need help with BIB design jbloud47 Full Range 9 22nd August 2007 09:38 PM
AJ-Horn & BiB - ar some BiB "parabolic"? freddi Full Range 3 6th April 2007 04:09 PM
Found cheap (remote!) 4-ch used VCA's for 2 way design with DCX2496 KBK Digital Line Level 3 14th February 2005 04:32 PM
Found a superb Op Amp design book Elkaid Everything Else 2 7th July 2003 11:22 PM
Copyright 1999-2017 diyAudio
