Just found the BIB design
Old 9th April 2013, 01:38 PM   #11
gafhenderson is offline gafhenderson  United Kingdom
Originally Posted by bvbellomo View Post
what if I invert this
Tried this, results weren't great. You get reflected waves back j to the pipe. Results in a kind of comb filter type sound in the higher frequencies that annoyed me.
Old 9th April 2013, 01:41 PM   #12
bvbellomo is offline bvbellomo
It seems others have had better luck (or at least been happier with the results). These are called ibib's on these forums.
Old 9th April 2013, 03:14 PM   #13
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Depends how far you space them off the floor, the floor construction / covering, and the internal damping.
Re the driver tap location (Zd/Zdriver), 0.217*L was what Terry Cain used in his RS 40-1354 pipe, which was itself derived from a box for the FF125K in the Fostex craft handbooks. It's close enough to the correct point to help kill the 5th harmonic, while as far as the original box at least was concerned, it also placed the driver at a reasonable ear-height. So no, it's not arbitary. Other tap locations that will provide decent results can be used as far as the pipe is concerned; how practical they would be physically is another matter -depends on the box size and configuration.
Old 9th April 2013, 03:58 PM   #14
GM is offline GM  United States
GM's Avatar
Is the entire 'terminus' area supposed to be open on top?
What if I invert this design?
Does anyone know the reason .217 was chosen?
Yes.
Floor loading the terminus can create a vent, lowering its tuning [Fp], but not having MJK's latest software I don’t know if it can be simmed.
Some say 0.21, others 0.217 is the point along the acoustical path-length where the first 5th is, but it varies depending on the pipe’s effective end correction once all boundary conditions are accounted for, so I’m not ‘wedded’ to either, especially since stuffing density will shift it also.
Frankly, I’ve never built a BIB per se, only ML-horns, i.e. restricted [vented] pipe horns [AKA Voigt pipe] based on a different acoustic path-length with the driver location much further down the pipe and the vent area [Av] = driver effective piston area [Sd]; neither did I use them for ‘full-range’ apps, only up to 500-750 Hz depending on the XO point, so how they might impact the driver’s mids/HF didn’t concern me too much.
That said, after seeing that MJK had calculated a 50% driver offset for his original ML-TQWT as opposed to my simple rule-of-thumb, I plugged in a few different ‘FR’ driver ML-horn alignments into his original freeware software and was pleasantly surprised at the results, so if one did a bit of fiddling with line length using a restricted terminus [vent] in his current software, up to a ~62% offset can be realized with good in-room results, especially if corner loaded.
For max practical pipe loading though, around 20-25% is required.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 9th April 2013, 04:35 PM   #15
I don't really understand the physics behind a TQWT. I would think we could think of a speaker as a 'room'. It reinforces even 1/4 wavelengths (1/2, 1, 1 1/2) and suppresses odd ones (1/4, 3/4, 1 1/4, etc). But that would mean a quarter wavelength tube would be the WORST length to choose, because it would suppress fundamental frequency. A BIB, being ½ wavelength, would be ideal.
Continuing our room analogy, our driver is either our speaker or listener (physics are similar). Again, we'd reinforce wavelengths at even 1/4 distances to the wall and cancel odd ones. So placement to cancel 1st harmonic would be 1/4, 1/2, 3/4 and 1 of our fundamental wavelength, and reinforcement (worse position) would be at 1/8, 3/8, 5/8 etc. Our fifth harmonic is 1/5 the length of our fundamental frequency. So good (canceling) position would be odd 1/20ths (1/20, 3/20, 1/4) etc and worst would be even 20ths (1/10, 1/5th, 3/10ths, etc). 0.217 is between 1/5th (worst) and 1/4th (good) but closer to 1/5th so this is a bad position to kill 5th harmonics. It isn’t good for 3rd harmonics or 7th. Using my logic, it is possibly the worst possible place to put the driver.
Old 9th April 2013, 05:06 PM   #16
I stand corrected. Some boundaries have 180 degree phase shift, others do not. Will post more after I have time to think.
Old 9th April 2013, 05:26 PM   #17
Scottmoose's Avatar
You may want to read this website:
Quarter Wavelength Loudspeaker Design
Old 9th April 2013, 05:27 PM   #18
If waves are reflected from closed surfaces with 180 degree phase shift, and from open boundaries without phase shift, then an opening at 1 end of the tube should behave the same as a closed tube ½ wavelength longer. This makes a TQWT effectively a ¾ wavelength room, which is still bad. A BIB becomes 1 ½ which is still good. So my logic doesn't change much.
Driver placement is not affected at all, as the end we are closest to is not open.
Old 9th April 2013, 05:38 PM   #19
Scottmoose's Avatar
Try looking through the website I linked to, and these:
Standing Waves
Resonances of open air columns
Old 9th April 2013, 07:08 PM   #20
Standing Waves
Good links, but they seem to agree with what I wrote. If a TQWT is a valid design (and I am sure it is) than I missed something somewhere, and need a good link that does not agree with what I wrote.
One point I did find that might be it:
"A conical air column will produce the same fundamental frequency as an open cylinder of the same length and will also produce all harmonics."
I've been thinking of these as a tube open at one end and closed at the other. Should I be thinking about this as a tube open at both ends? Or is this just because the site is primarily concerned with instruments, and the end you blow into behaves differently?
If a TQWT really behaves as a cylinder open on both ends, it has the same modes as a 1 1/4 wavelength closed cylinder, which still suppresses the fundamental frequency, so that doesn't help.
Just found the BIB designHide this!Advertise here!
Small 2" drivers in BIB design Gugi Full Range 22 16th February 2011 07:01 PM
Need help with BIB design jbloud47 Full Range 9 22nd August 2007 09:38 PM
AJ-Horn & BiB - ar some BiB "parabolic"? freddi Full Range 3 6th April 2007 04:09 PM
Found cheap (remote!) 4-ch used VCA's for 2 way design with DCX2496 KBK Digital Line Level 3 14th February 2005 04:32 PM
Found a superb Op Amp design book Elkaid Everything Else 2 7th July 2003 11:22 PM
