Fostex, Sigma or not ? - Page 2 - diyAudio
Old 9th April 2013, 06:07 PM   #11
barackuda's Avatar
Hi Jazzminded...
I am building a B&W style enclosure for the Fostex, look here:
FE168E Sigma teardrop enclosure
scrool down a little.
Danny
Old 10th April 2013, 05:19 PM   #12
hpeter is offline hpeter  Slovakia
hpeter's Avatar
thanks for all replies
BLOG. XMOS_U8/PCM5102A > LL1544A > 6H1Pi+µfoll > 2A3_SOV/JJ > LL1660 > STAX SR207 _ SR L300 _ SR007 # LL2748 > 394A > LCLC 4H/100µ
Old 10th April 2013, 08:43 PM   #13
barackuda's Avatar
Peter, decided yet? we want to hear it.....
Danny
Old 11th April 2013, 05:21 PM   #14
hpeter's Avatar
Danny
ofcourse not yet, now i will be in long brainstorming period
i am that kind of person which is unable to decide fast
maybe frugal horn or i dont know for sure yet
Old 11th April 2013, 07:39 PM   #15
barackuda's Avatar
take your time, look at many enclosures and drivers as you can, listen to even more if you can.....
good luck
Danny
Old 13th April 2013, 09:18 PM   #16
Default 8" wide range comparison.
I have compared multiple wide-range drivers in an open baffle with bass support using Eminence 15 alpha in Martin style H-frames. For extented midrange use (200 to 4KHz) application with low wattage tubeamps (like miniwatt), the Fostex 208 EZ sounded the warmest and best balanced compared to TB-1808, Fostex 225WK, Eminence 12LTA, AN-10 and some other less expensive ones. However, the 208EZ will need a tweeter whereas the TB1808 can cover the upper range after some taming of the highs.
However the higher efficiency of the 208EZ makes it the most suitable to get live SPL levels even with a 3.5W tube amp. But more the efficiency, bigger the cabinet size to get the same bass extension, or biamplify with bass support. If you are using a "high" powered tube amp, FF225WK with tweeter or TB1808 with a few notch filters (at the cost of narrower dispersion) will allow a floor standing MLTL as a cabinet option.
Disadvantage for place the Fostex 168e sigma into Fostex 166e BLH enclosure ? davidshya Full Range 2 27th January 2013 09:41 PM
Fostex FE208E Sigma bbr81 Full Range 14 13th October 2011 08:14 PM
Fostex Fe168e Sigma Jamesuk1 Full Range 1 29th May 2008 05:51 PM
fostex fe168E Sigma brian t Full Range 5 6th January 2005 10:16 PM
Fostex 208E-Sigma TaaJ Multi-Way 10 12th October 2004 08:00 PM
Copyright ©1999-2017 diyAudio
