Black Beauty 2013 - a compact monitor with the CHR70A
Old 5th April 2013, 11:18 PM   #1
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default Black Beauty 2013 - a compact monitor with the CHR70A
Back in 2009 I made a compact monitor for the CHR70 gen1, the Black Beauty. This design also worked for the gen2, but the gen3's parameters differ too much to just drop them in.
So it was back to the virtual drawing board... I set for myself as a goal, to not only have a similar compact design, but to be able to offer all those who built the original Black Beauty the possibility to upgrade with minimal mods. After fiddling with LspCAD for a while, I came to a low tuned, well damped BR alignment that had the potential of sounding rather nice in the bass department:
It does not extent as far down as the original BB, but has a small raise in the response just above 100Hz, which should give it a nice "commercial" sound. The low tune helps in keeping the cone excursion down in the bass drum area.
So this Easter weekend (yes, this is this year's Easter Project) I started building the cabinets, of course also from black MDF:
The MDF ready to be glued together. As you see, I have attached high density damping material ("Bondum 800") to the walls, there will be some normal Sonofil/Accoustastuff in the centre
more work in progress
And ready for testing:
After running them in (Vivaldi's winter on repeat) for as long as my patience allowed I hooked them up to my PC for a first impression. That was not good, for the small cabinet gives a big hump in the midrange response.... but I expected that, so a quick correction with the VLC mediaplayer's graphic equaliser made the tonal balance OK, so I could test it a bit with some of my playlists. Long story short: great sound, passed the gate to further work on a filter. Bass sounded as expected, not deep but good presence and punch. All other qualities as I know them from Mark's drivers, so no need to repeat how good they sound
[to be continued ..... ]
Old 5th April 2013, 11:38 PM   #2
markaudio is offline markaudio  Hong Kong
markaudio's Avatar
Hello Henkjan,
Many thanks for posting this info. Its a very nice looking project. Hope you can keep guys informed on further progress re filters and how it sounds as the drivers fully run-in.
Are the dimensions of the new box similar to the original Black Beauty?
Cheers
Mark.
Old 5th April 2013, 11:42 PM   #3
Henkjan's Avatar
Hi Mark, you're up early again
Thanks to you and your team for the driver in general, and for the effort to get this pair to me in time for Easter
I have done some development of the filter and listened some more , but I'll write that tomorrow, it's past midnight here...
they are identical, the main difference is 1 extra hole for the BR tube
Old 6th April 2013, 06:53 AM   #4
sayrum is offline sayrum  Germany
Good morning,
thanks for developing the next beauty!
I would love to see some unsmoothed frg for the high frequencies.
Have a good we everyone,
Daniel
Old 6th April 2013, 02:15 PM   #5
Henkjan's Avatar
what I measured looks prety much in line with the datasheet and measurements I saw in for example the Hobby Hifi, so an on-axis rising high with 2 peaks above the 10kHz. What is it specifically you are looking for that cannot be seen from the graph in the datasheet? Maybe Mark can help out here, since his measurements were done with a lot better gear than mine
Old 6th April 2013, 10:36 PM   #6
Henkjan's Avatar
Originally Posted by Henkjan View Post
....they are identical, the main difference is 1 extra hole for the BR tube
so here is the dimensional drawing:
the material used is 16mm black MDF
And this is the BR tube I used:
This results in a tune of somewhere between 50Hz and 55Hz, dependent on the amount of stuffing used. This particular tube requires a precisely drilled hole of 48mm diameter (49 is the max tolerable).
I placed the port on the back of the cabinet, and I advise this to do this always when making a BR for a full range (or classic 2way; with a 3way of FAST where the bass does not have to do also the mids there is no problem with the BR port in the front) to avoid the mids coming out of the BR tue messing up the response and imaging.
Old 6th April 2013, 11:45 PM   #7
Henkjan's Avatar
After the test on the PC, I did some quich measurements followed by a few sims to get a good starting point for a correction filter:
so, 1 option is a single RCL, the other a correction using 2 RCLs
On listening I found little difference, so I did a check measurement:
which explains why I did not hear much difference, because there is not much difference in the response....
So back to the 1 RCL, changed the R to 12ohm (so now a 0.68mH coil, 11.5uF (6.8+4.7) capcitor, and 12ohm resistor) and listened some more.... placement was not optimal (a bit too high), but had to do for the moment (I was not in the front when they handed out patience )
First impressions: I am very pleased with how the sound already, I could have these how they are now and be happy with them as my only speakers. Excellent imaging, neutral sound (not a hint of sharpness), beautiful details in the music, decent bass response. yes, I miss the deep bass in some recordings, but that was to be expected (I am a bit spoiled, in both my normal sets I have 10" woofers taking care of that).
So, for the moment I can already recommend the design in its current state: BB cabinet (well damped), BRHP35 tube, CHR70A, and a correction of a 0.68mH coil, 11.5uF (6.8+4.7) capcitor, and 12ohm resistor is enough to enjoy music, all else is luxury
I might post more updates later as I listen and test more, but that will take some time...
Old 7th April 2013, 08:45 PM   #8
Henkjan's Avatar
the filter schematic:
atm I listen to the 12ohm version, but I would advise to experiment and adjust acc your own taste and listening environment
Old 7th April 2013, 09:38 PM   #9
Thanks for creating the updated BB and posting mesurments.
The steep rise at ~6Hz and the general alpine look of the curve is what i expected from these drivers, not my cup of tea...
Old 7th April 2013, 11:15 PM   #10
Henkjan's Avatar
Have you listened to them before judging them?
The measurements I made are to help in developing the filter, nothing else. you can't judge any driver on just 1 curve. A rise at higher frequencies on-axis is what you see with most full range drivers, and this is not an error but is often actually required so the power average and/or off axis response is neutral.
Black Beauty 2013 - a compact monitor with the CHR70AHide this!Advertise here!
Sprague Black Beauty caps 0.33uF QSerraTico_Tico Swap Meet 0 28th July 2012 11:10 AM
Sprague Black Beauty caps QSerraTico_Tico Swap Meet 0 28th July 2012 11:05 AM
Black Beauty volume for tube lover Praudio Swap Meet 2 18th February 2009 04:30 PM
Anyone tried Black Beauty caps?? jamesjung21 Parts 9 31st August 2004 06:30 AM
FS. Alps Black Beauty balance pots Mark Hathaway Swap Meet 0 20th April 2003 04:01 AM
