Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
#21 | |
The measured TSP's are realistic and you can use them to calculate enclosures. The m4 version will only have a different impedance (4ohms) |
#22 | |
#23 | |
btw here's the plan I forgot to include in my last post. |
#24 |
Hi, FYI
A few more observations I've made: b ![]() |
#25 |
Thanks for the informations, and we are waiting for more
#26 |
Hi all.
Interesting indeed. Thanks for all the graphs. I will assume my set works like that as well instead of measuring it(as I'm not clued up on all that), just to start playing around. Just to see if I understand these M8 measurements correctly.... If you were to use yours(ad12100 m8 as per the freq response graphs in this thread) in a simple OB and cross over the AD12100 M8 at some point in the higher frequencies to a suitable tweeter, say HE super tweeter... What would you do/ where would you cross ? (10K ?) and if so, how would you do that ? a single cap or ? The reason why I ask, is cause I'm really happy with my M8 as a single driver in JELABS ob ,,,,really just to get rid of the sharp / harsh high frequencies at higher volume(which is my experience with the M8 on a JE LABS OB ).... Kind regards, Julian. |
#27 |
#28 |
Well I do love your design!
#29 |
#30 |
Is not the bass very loose in such a large cabinet? When I listen to my 12100/HP I think it is more of a midbass speaker suitable for a similar enclosure as a JBL 2202H. I will make a 47L and switch between JBL 2202H and the Philips. They will enforce the midbass section in my compression driver horn system.
Thread | Thread Starter | Forum | Replies | Last Post |
Philips AD12100-hp8 on open baffle ??? | Leonidas | Full Range | 25 | 5th August 2016 12:04 AM |
Philips AD5061 M8 | martino9 | Swap Meet | 3 | 21st March 2015 01:21 PM |
FS: 14 x Philips Speaker: 1265/W8 + 1265/M8 + 9710/M8 | jdkwant | Swap Meet | 1 | 6th March 2014 12:24 AM |
Philips AD8080/M8 | lochness | Full Range | 1 | 15th June 2008 05:40 AM |
Philips AD70850 M8 | PTSOUNDLAB | Full Range | 22 | 5th June 2007 05:35 PM |
New To Site? | Need Help? |
